When I use TMPGEnc to extract Divx video into MPEG2 using the DVD(NTSC) template... modified to extract video only... I get a message fom DVDit that the MPEG2 to is valid, but is not identifiable as NTSC or PAL.
What am I doing wrong in TMPGEnc?
Are you using DvdIt PE V2.5. If so try the following:
in TmpGenc, load the DVD(NTSC) template. Then load unlock.mcf from the extras folder. Click the settings button. On the advanced tab ensure that 3:2 pulldown is NOT checked. On the GOP structure tab set Number of P picture in GOP to 4, not 5 as is set by the template. Click OK. Under Stream type select the video only button. Hit start and wait. When the encode is complete use pulldown.exe to apply the 3:2 pulldown flags if required. (if your divx is 23.97 fps you will need to do this, if it is 29.97 fps you can skip this bit). Dvdit should now accept your video. You will need to supply the audio seperatley. I suggets extracting from the Divx with virtualdub, convert to PCM (uncompressed) 48Khz and save as a wav file. Use this to provide the audio track to DVDit. This may also work with versions of DvdIt other than PE 2.5. Let me know how you get on.
P.S. If you load the video file in TmpGen cAFTER the template, it screws up many of the settings, always select your video/audio source BEFORE applying the template. -
I will try the process you descirbed. Do you think it would be okay for me to change from VBR to CBR and set a specific bitrate. Using a bitrate calculator, I am reducing the bitrate so it will fit on one DVD+RW.
I got pulldown here: http://guiguy.wminds.com/downloads/pulldownbatchfe/down.html
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
How to Embed ANY IDENTIFIABLE Information in a Video WITHOYT RE-ENCODING?
By Windfall in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2008, 14:13
