When my wired router is on connected by Ethernet cable I can't access any websites using my usb internet stick. The usb internet will connect, but the web page on bottom says resolving host... & the page doesn't load up.
Should this be possible? It's the only internet I have & would like to maintain a home network.
Results 1 to 9 of 9
USB internet stick ?
do you mean a cellular internet data connection ?
why are you connected to router, if your using cell internet ? are networking other devices, can they use Wifi to connect to the PC
unplug the router
establish your cell internet
now plug in your router
you may have to goto the control panel and set the ethernet port to Local Aera Network Only AKA LAN only no internet
your pc thinks the router is for internet, its blocking access on the cell stick -
Was using router just for NAS access only. Ill try your advice.
EDIT: this is the type of internet I have,
My computer, its just a stick plugged in usb slot, no adaptor as I understand.Last edited by Gurd99; 6th Aug 2015 at 03:59.
Yes cellular data networking
The key word is *network*
You can't have multiple networks, without some kind of bridging
The laptop sees the LAN as a network, which it is
And it sees the USB modem as a NETWORK which it is..
Your gateway to the internet and millions of computers
The LAN has to be isolated by settings aka addressing , so the pc can use it only for device access
As a last resort you can maybe change the NAS over to USB connection
Or just not connect it when you want to be online
BUT You should be able to isolate it with the correct settings -
I assume you're talking about Usb/wifi (wireless)
Enable DHCP on your router, this should solve the issue*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
No it's not Wi-Fi
It's a cellular modem, connects to Tele p home cell towers
Data only signal via cell tower
When he is connected to the router and plugs in the cell modem the internet never connects at the pc level
If the router aka nas network is not connected to the pc the cell modem internet works
Dchp might help, but it is not WiFi the internet does not go thru his router,no cable no fios , dsl -
Still guess work
Sounds like a clash in ip addressing between nas and usb telco device
Check telco device network settings and that of nas (the nas device needs to be changed)
This is also vista and nothing ever goes well, sometimes it works and other times its a mess.
[Solved] Slow internet only through router
By Sakuya in forum ComputerReplies: 23Last Post: 13th Nov 2014, 22:32 -
Camcorder not recognized when connected with firewire to USB
By shaileng in forum Capturing and VCRReplies: 5Last Post: 23rd May 2013, 13:56 -
Media Player with 5+ TB connected via USB?
By Jay4 in forum Media Center PC / MediaCentersReplies: 9Last Post: 18th Jun 2012, 18:05 -
Ripping Video Stream from Internet Connected / Networked BluRay Player...
By salinesky in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Jun 2011, 12:58 -
cannot connect to internet via router hardwired to pc yet get wireless
By ultrarunner in forum MacReplies: 17Last Post: 29th Sep 2010, 14:19
