  1. As I installed SE 3.4.7 automatic translation doesn't work.
    I have this messege.
    Is this some bug, or Google mistake?
  2. I have same message on SE 3.4.7
    Download and install new version 3.4.8
  3. Thanks, worked. And one question:
    how to remove history of opened files, in picture
  4. Setting and history of opened files saved to file C:\Users\{user name}\AppData\Roaming\Subtitle Edit\Settings.xml
  5. Or in case you use the portable version wherever you installed it.
  6. Thanks man. I run XP, can't find above. Yet strange thing that reset can't do from Settings, and must reinstall.
    Subtitle Workshop have this
