Hi Everyone,
I recently installed Sony Vegas 13 Pro, and after creating a project and rendering it, i've been unable to play the rendered 4k file. Any tips? The source file is 4096x2304 at 23.976p and is an mp4. I've aligned the preferences, and created a custom template for the render, but still nothing...
I should clarify that the render completes 100%, however when i attempt to play back the rendered file, i just get a black screen.
Check the Sony Forum. http://www.sonycreativesoftware.com/forums/showtopics.asp?forumid=4
In additions to budwzr's link you could try a lower render resolution and see if that will play. 1920x1080 for instance. If that works then you know your computer may have problems playing 4k.
Extraordinary claims require extraordinary evidence -Carl Sagan
sony vegas rendering issues
By yogurtpooh in forum EditingReplies: 18Last Post: 8th Feb 2013, 11:32 -
Premiere rendering jerkyness or acceleration rendering with MJPEG sources.
By Sennyotai in forum Video ConversionReplies: 4Last Post: 12th Jan 2013, 13:29 -
What is Rendering?
By jbitakis in forum Video Streaming DownloadingReplies: 4Last Post: 1st Jan 2012, 23:27 -
Issues with low memory while rendering Vegas 11
By magic612 in forum EditingReplies: 28Last Post: 8th Dec 2011, 19:49 -
HD Editing/Rendering issues
By MelonMinty in forum EditingReplies: 1Last Post: 1st Nov 2010, 09:29
