Results 1 to 9 of 9
  1. Hello,
    I use mkvmerge extensively -- it is a very convenient tool for me.
    However, I notice no track appears under "General track options" Tab -- no audio/video track at all!
    I tried under MKVMerge from version 7 to 8.0 (latest 8.2 is for Vista and later OS).
    No results.
    What has gone wrong?
    Please help.
    Thanks.
  2. More info needed
    under "General track options" Tab its option for track, not track list
    can you post image screenshot?
  3. Click image for larger version
    Originally Posted by roma_turok View Post
    More info needed
    Thanks.
    The info below "General track Options" Tab is blank and the fields are greyed out.
  4. Is it only that video that has a problem? Try another video to see if it works . eg. try a random mp4 downloaded from youtube
    Maybe try an even older version of mkvmerge
    https://www.videohelp.com/software/MKVtoolnix/old-versions#download
  5. That what happens if you change to BIG windows configuration in XP:
    Change back to default windows XP Theme:
  6. @poisondeathray
    Thanks. I tried with many versions… no change.
    @roma_turok
    Yes I have selected Large in Display.
    Will try and get back.
    Thanks.
  7. Originally Posted by ConverterCrazy View Post
    I think XP compatibility was restored in 8.0. I don't have XP so I cannot test it but roma_turok's screenshot made with 8.2.0 under Windows XP seems to confirm this. If you get 8.2.0 it will bring along a completely new GUI called "MKVToolNix GUI". The old one will be removed in a future version so you might as well just start using the new one.
  8. @roma_turok
    Bingo!
    Your suggestion worked
    I keep screen fonts big to avoid eye-strain but many tools/applications don't seem to understand and appreciate my choice
    It goes even for other versions of OSes.
    @sneaker
    Thanks for the input. I'll try it.
  9. @sneaker
    Yes, MKVTools 8.2 works under Windows XP.
