Hi, does anyone here know of a good remuxer with a user friendly interface, that can batch or queue alot of remuxes at once?
If you do suggest a converter, please make sure it can copy the audio/video streams from MKVs and remux them into MP4s.
My System Info:
PC Model: HP 110-326 Desktop
Motherboard: Hewlett Packard 2AFB (Ivy Bridge)
OS: Windows 8.1 64-bit
CPU: Intel Pentium G2100T @ 2.60 GHz Dual Core
Video Card: Intel HD Graphics 2500 (1920x1080x32bpp 60Hz)
Sound Card: Realtek High Definition Audio
RAM (Memory): 4.0 GB Single Channel DDR3 @ 665 MHz
HDD Space: 500 GB Western Digital Caviar (SATA III)
Network Adapter: Realtek USB FE Family Controller @ 100.0 Mbps
Mkv2mp4 won't do batch remuxing. (you have to add each file) If you have all your Mkv's in one folder, mkv/avi to mp4 will do batch remuxing. The program hasn't been updated in 5 years, but i've had less problems with it than Mkv2mp4.
This film is presented in it's original 2.35:1 aspect ratio. The black bars at top and bottom are normal. (it's you that isn't normal) -
"The greatest trick the Devil ever pulled was convincing the world he didn't exist."
Thanks for trying to help, but I can't get that program to re-encode HE-AAC audio to LC-AAC audio.
Otherwise it is what I wanted.
Thanks man, will be sure to try that one out soon.
I'll try this one out if mkv/avi to mp4 doesn't work, but thanks for the suggestion.
Trying to convert multiple mkvs to avi to play on divx dvd player?
By ericc54321 in forum Video ConversionReplies: 6Last Post: 23rd Mar 2014, 23:57 -
[Help] Remux multiple mkv with ssa
By remuxler in forum EditingReplies: 3Last Post: 10th Jun 2013, 16:51 -
MkvToolnix (MKVMerge 6.1.0) on Mac OS X 10.8.2 - Merging Multiple MKVs
By tedallen in forum Video ConversionReplies: 2Last Post: 20th Mar 2013, 17:35 -
Blu-ray player cutting off sides of 16:9 mp4s/mkvs
By travbrad in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2012, 21:40 -
Windows won't recognize/open MKVs
By CasanovaFly in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2010, 11:06
