Hello,
i have done some tests and i created a list with the working sample formats per format and encoder in FFmpeg.
Here it is :
(Updated on 08.02.2015)
Code:MP3 - MPEG Layer 3 Audio - Libmp3lame sample_fmt="s16p,s32p,fltp" AAC - Advanced Audio Coding - AAC (Advanced Audio Coding) sample_fmt="fltp" OGG - Ogg Vorbis Audio - Libvorbis sample_fmt="fltp" OGG - Ogg Vorbis Audio - Vorbis sample_fmt="fltp" WMA - Windows Media Audio - Windows Media Audio 2 sample_fmt="fltp" WMA - Windows Media Audio - Windows Media Audio 1 sample_fmt="fltp" OPUS - Opus Interactive Audio Codec - Opus (Opus Interactive Audio Codec) sample_fmt="s16,flt" RA - RealAudio 1.0 - RealAudio 1.0 (14.4K) sample_fmt="s16,s16p" MP2 - MPEG audio layer 2 - mp2 sample_fmt="s16" MP2 - MPEG audio layer 2 - libtwolame sample_fmt="s16,flt,s16p,fltp" AC3 - Dolby Digital - ac3 sample_fmt="fltp" AC3 - Dolby Digital - ac3_fixed sample_fmt="s16p" EAC3 - Dolby Digital Plus - eac3 sample_fmt="fltp" DTS-DCA - (DTS Coherent Acoustics) - dca sample_fmt="s32" AMR - Adaptive Multi-Rate Audio Codec - AMR-NB (Adaptive Multi-Rate NarrowBand) sample_fmt="s16,s16p" AMR-WB - Adaptive Multi-Rate Wideband - AMR-WB (Adaptive Multi-Rate WideBand sample_fmt="s16,s16p" SPX - Speex - spx sample_fmt="s16" iLBC - (Internet Low Bitrate Codec) - libilbc sample_fmt="s16,s16p" FLAC - Free Lossless Audio Codec - FLAC (Free Lossless Audio Codec) sample_fmt="s16,s32" ALAC - (Apple Lossless Audio Codec) - ALAC (Apple Lossless Audio Codec) sample_fmt="s16p,s32p" WV - Wavpack - Wavpack sample_fmt="u8p,s16p,s32p,fltp" WV - Wavpack - Libwavpack sample_fmt="s32" WAV - Waveform Audio - PCM A-law G.711 A-law sample_fmt="s16" WAV - Waveform Audio - PCM mu-law G.711 mu-law sample_fmt="s16" WAV - Waveform Audio - PCM 32-bit floating point big-endian sample_fmt="flt" WAV - Waveform Audio - PCM 32-bit floating point little-endian sample_fmt="flt" WAV - Waveform Audio - PCM 64-bit floating point big-endian sample_fmt="dbl" WAV - Waveform Audio - PCM 64-bit floating point little-endian sample_fmt="dbl" WAV - Waveform Audio - PCM signed 16-bit big-endian sample_fmt="s16" WAV - Waveform Audio - PCM signed 16-bit big-endian planar sample_fmt="s16p" WAV - Waveform Audio - PCM signed 16-bit little-endian sample_fmt="s16" WAV - Waveform Audio - PCM signed 16-bit little-endian planar sample_fmt="s16p" WAV - Waveform Audio - PCM signed 24-bit big-endian sample_fmt="s32" WAV - Waveform Audio - PCM D-Cinema audio signed 24-bit sample_fmt="s16" WAV - Waveform Audio - PCM signed 24-bit little-endian sample_fmt="s32" WAV - Waveform Audio - PCM signed 24-bit little-endian planar sample_fmt="s32p" WAV - Waveform Audio - PCM signed 32-bit big-endian sample_fmt="s32" WAV - Waveform Audio - PCM signed 32-bit little-endian sample_fmt="s32" WAV - Waveform Audio - PCM signed 32-bit little-endian planar sample_fmt="s32p" WAV - Waveform Audio - PCM signed 8-bit sample_fmt="u8" WAV - Waveform Audio - PCM signed 8-bit planar sample_fmt="u8p" WAV - Waveform Audio - PCM unsigned 16-bit big-endian sample_fmt="s16" WAV - Waveform Audio - PCM unsigned 16-bit little-endian sample_fmt="s16" WAV - Waveform Audio - PCM unsigned 24-bit big-endian sample_fmt="s32" WAV - Waveform Audio - PCM unsigned 24-bit little-endian sample_fmt="s32" WAV - Waveform Audio - PCM unsigned 32-bit big-endian sample_fmt="s32" WAV - Waveform Audio - PCM unsigned 32-bit little-endian sample_fmt="s32" WAV - Waveform Audio - PCM unsigned 8-bit sample_fmt="u8" WAV - Waveform Audio - SEGA CRI ADX ADPCM sample_fmt="s16" WAV - Waveform Audio - G.722 ADPCM sample_fmt="" WAV - Waveform Audio - G.726 ADPCM sample_fmt="" WAV - Waveform Audio - ADPCM IMA QuickTime sample_fmt="s16p" WAV - Waveform Audio - ADPCM IMA WAV sample_fmt="s16p" WAV - Waveform Audio - ADPCM Microsoft sample_fmt="s16" WAV - Waveform Audio - ADPCM Shockwave Flash sample_fmt="" WAV - Waveform Audio - ADPCM Yamaha sample_fmt="s16" WAV - Waveform Audio - MP3 (MPEG audio layer 3) sample_fmt="s16p,s32p,fltp" WAV - Waveform Audio - GSM Microsoft variant sample_fmt="" CAF - Core Audio Format - PCM A-law G.711 A-law sample_fmt="s16" CAF - Core Audio Format - PCM mu-law G.711 mu-law sample_fmt="s16" CAF - Core Audio Format - PCM 32-bit floating point big-endian sample_fmt="flt" CAF - Core Audio Format - PCM 32-bit floating point little-endian sample_fmt="flt" CAF - Core Audio Format - PCM 64-bit floating point big-endian sample_fmt="dbl" CAF - Core Audio Format - PCM 64-bit floating point little-endian sample_fmt="dbl" CAF - Core Audio Format - PCM signed 16-bit big-endian sample_fmt="s16" CAF - Core Audio Format - PCM signed 16-bit little-endian sample_fmt="s16" CAF - Core Audio Format - PCM signed 24-bit big-endian sample_fmt="s32" CAF - Core Audio Format - PCM signed 24-bit little-endian sample_fmt="s32" CAF - Core Audio Format - PCM signed 32-bit big-endian sample_fmt="s32" CAF - Core Audio Format - PCM signed 32-bit little-endian sample_fmt="s32" CAF - Core Audio Format - PCM signed 8-bit sample_fmt="u8" CAF - Core Audio Format - ADPCM IMA QuickTime sample_fmt="s16p" CAF - Core Audio Format - ADPCM IMA WAV sample_fmt="s16p" CAF - Core Audio Format - ADPCM Microsoft sample_fmt="s16" CAF - Core Audio Format - MP3 (MPEG audio layer 3) sample_fmt="s16p,s32p,fltp" AIFF - Audio Interchange File Format - PCM A-law G.711 A-law sample_fmt="s16" AIFF - Audio Interchange File Format - PCM mu-law G.711 mu-law sample_fmt="s16" AIFF - Audio Interchange File Format - PCM 32-bit floating point big-endian sample_fmt="flt" AIFF - Audio Interchange File Format - PCM 64-bit floating point big-endian sample_fmt="dbl" AIFF - Audio Interchange File Format - PCM signed 16-bit big-endian sample_fmt="s16" AIFF - Audio Interchange File Format - PCM signed 16-bit little-endian sample_fmt="s16" AIFF - Audio Interchange File Format - PCM signed 24-bit big-endian sample_fmt="s32" AIFF - Audio Interchange File Format - PCM signed 32-bit big-endian sample_fmt="s32" AIFF - Audio Interchange File Format - PCM signed 8-bit sample_fmt="u8" AIFF - Audio Interchange File Format - PCM unsigned 8-bit sample_fmt="u8" AIFF - Audio Interchange File Format - ADPCM IMA QuickTime sample_fmt="s16p" AU - SUN AU Format - PCM A-law G.711 A-law sample_fmt="s16" AU - SUN AU Format - PCM mu-law G.711 mu-law sample_fmt="s16" AU - SUN AU Format - PCM 32-bit floating point big-endian sample_fmt="flt" AU - SUN AU Format - PCM 64-bit floating point big-endian sample_fmt="dbl" AU - SUN AU Format - PCM signed 16-bit big-endian sample_fmt="s16" AU - SUN AU Format - PCM signed 24-bit big-endian sample_fmt="s32" AU - SUN AU Format - PCM signed 32-bit big-endian sample_fmt="s32" AU - SUN AU Format - PCM signed 8-bit sample_fmt="u8"
Results 1 to 1 of 1
For which formats ffmpeg can import album art and how ?
By alexander121 in forum AudioReplies: 2Last Post: 16th Jun 2015, 11:40 -
List of available ffmpeg encoders for each container format
By alexander121 in forum Video ConversionReplies: 4Last Post: 8th Jan 2015, 06:53 -
list colorspaces supported for each codec in ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2013, 06:33 -
[C++] My custom FFmpeg wrapper for batch conversion between formats
By AlecTaylor in forum Video ConversionReplies: 0Last Post: 7th Jun 2011, 14:43 -
How to change sample rate in FFMPEG
By MackanZoor in forum AudioReplies: 5Last Post: 24th Jan 2011, 13:31
