Ok, thanks. I got the point. Nothings's easy... So let's say QTGMC "faster" is optimal enough? My laptop will probably die soon). I'm so green in avisynth, can you direct me to some good guide to figure this task out?
Maybe I check it out, one person on this forum suggested that also, if it's easier/faster than avisynth (I guess I have to find some average if I don't want to put my 4 year old laptop to halt). Or should I just stick to avisynth?Nothing straight forward. Maybe Cineform can batch transcode to cineform (visually lossless format) using solid bob deinterlace with one nice graphic user interface, not sure.
Results 31 to 38 of 38
... or do not crop your video, then you do not need those intermediate files ...
What do you mean, dmfs is not direct export
it can be set up so Avisynth script is created automatically: dmfs avi to mp4.zip
by creating proper INI file you can have many export scenarios, we always tend to use a couple of templates only anyway and use it all over again ...
All NLE would have problem to crop interlace footage (crop and resize back to original resolution), Premiere, Vegas, not sure about Edius or Pro's tools like Final Cut ProX, Avid Media Composer but I bet it is the same. All they have its way to reduce interlace flicker or how specifically it is called within each of those software, more or less, you'd need to look and tweak it in every specific software to find a way to make it look better ... -
I might do like that, but after I get the video nicely deinterlaced. I'll try out all the nice suggestions in this post when I'll have more time. I've learned a lot here recently.
Best deinterlacing in Vegas pro?
By Srivas in forum EditingReplies: 28Last Post: 15th Mar 2024, 15:05 -
How to retain video effects and quality of video in Sony Vegas?
By YoTiffLBrockz in forum EditingReplies: 10Last Post: 14th May 2014, 00:37 -
Any app to retain more sharpness when upscaling?
By brassplyer in forum Video ConversionReplies: 12Last Post: 23rd Jan 2014, 18:00 -
240 fps rendering with Sony vegas pro 12 and other good Q's
By Muffdiever in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jan 2013, 11:34 -
Is Sony Vegas Movie Studio HD Platinum 10 a good editing software?
By vid83 in forum EditingReplies: 8Last Post: 4th Feb 2011, 08:02
