Hi guys,
I must code an app to put user defined metadata in AVI files.
Those metadata are binary, not text, and quite big (the ultimate size is not well defined).
I spent some time googling about but at the end I haven't clear if it is actually allowed to add this kind of metadata without breaking the AVI standard.
Does anybody know if it is possible and if there is a limit in size to those metadata?
Data in AVI files appears in "chunks". A chunk starts with a fourcc code identifying what that chunk is. That is followed by a four byte size (the size of the chunk, up to 4 GB, though in practice you should stick with less than 2 GB because some software uses signed inters rather than unsigned integers), then the the actual data of that chunk. So you can define your own fourcc and put whatever you want in that chunk. That will work fine with your own software since you will know how to deal with it. Other software will will just skip over it and proceed to the next chunk. If you want your metadata to be usable by other programs you'll need to stick with defined standards.
A good place to stick something like this might be the "Junk"chunk. Most other apps would ignore it and there is no clear defined format for its contents.Know, however, that some other apps may want to stick their own junk in there (probably overwriting yours).
Metadata in AVI files
By farklem in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jan 2020, 21:11 -
.mov files metadata stamp?
By David22 in forum EditingReplies: 1Last Post: 10th Jun 2014, 00:40 -
Preserving Time / Date metadata in capture files
By jlaymon in forum Capturing and VCRReplies: 4Last Post: 28th May 2013, 12:51 -
Adding Metadata to Video Files
By yardline in forum Video ConversionReplies: 8Last Post: 28th Oct 2012, 21:29 -
MediaInfo Encoding Settings to MKVMerge User Defined Options
By maneck35 in forum Video ConversionReplies: 2Last Post: 22nd May 2012, 13:21
