    Jul 2015
    Hi all. I'm wondering what the best way would be of cleaning up a video file of a scumbag trying to break into my car. It is mp4 format and I have zero experience in doing this. Thanks!!!!!
  2. If you upload the video here, someone will try to help you or at least make some suggestions as to what can be done about it . There is an "upload files" button
    But don't get your hopes up too high - if it's typical security footage the resolution and lighting conditions are usually too poor. Real life is nothing like "CSI" on TV
    Jul 2015
    Here you go. Thanks in advance for any help you can give
  4. Sharpening will just increase the noise. You've got a very good look at the guy's face front and profile. Take it to the police as-is.
    Increasing the contrast may make it more aestheically pleasing, but all you're doing at that point is tampering with evidence and making your case more difficult.
    Not sure they're going to do much about what is at worst a minor tresspassing infraction anyway.
  5. The video is already sharp. What it suffers from is a lack of detail -- from over compression.
    FWIW: Image
    [Attachment 32882 - Click to enlarge]
