Hello.
I have many BDRips as MKV, but I need to change them to MP4 (for streaming; iTunes to Apple TV). I'm not huge into Apple, but own an Apple TV already and this seems like the easiest way (?).
However, I'm not sure how to do this. The Remuxes I have are easy - just throw then into Handbrake overnight. But I don't know how I can just change the wrapper on rips that are already H.264 encoded.
I also need to change the audio from DTS-HD (usually) to AAC or something Apple TV will play. How can I do both without re-encoding, wasting time, no video quality loss, etc.?
I've tried MKVToMP4, and the conversion worked, but I don't know if this is re-encoding or not? I usually end up with a significantly smaller file.
Any help would be appreciated! Thanks!
I re-tested MKVtoMP4. It takes anywhere between ~10 to 20 minutes to convert. Many of my Blu-rays are ripped H.264 2-pass with ~15k Kbps average (sometimes ~14k Kbps) with DTS-HD. I also have remuxes, but if I'm converting those I usually just throw them into Handbrake overnight and keep the H264 rip (unless there is a visual difference, but that is rare).
As an example for MKVtoMP4, I tested Edge of Tomorrow; it is 2-pass ~14k Kbps average, DTS-HD, at 15.2 GB. It came out at 11.2 GB with AAC (default settings) and it took ~10 minutes.
Does that sound about right? Is this the most efficient way to do this? I just convert them to M4V so I can stream to Apple TV (or whatever else; not sure what Roku/Chromecast support, but I doubt they play MKV, at the least) and then usually delete them when done (or archive them).
Thanks!Last edited by MKV; 30th Jul 2015 at 20:38.
Looking for copy of avs2avi wrapper v0.3
By DRP in forum Video ConversionReplies: 51Last Post: 10th Sep 2012, 18:40 -
BatchShrink, a batch wrapper for DVD Shrink 3.2
By midders in forum DVD RippingReplies: 22Last Post: 12th Feb 2012, 02:12 -
[C++] My custom FFmpeg wrapper for batch conversion between formats
By AlecTaylor in forum Video ConversionReplies: 0Last Post: 7th Jun 2011, 14:43 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 21:30
