Results 1 to 11 of 11
  1. Does anyone know where I can get a bullet hole transition?
  2. Since "bullet hole" is not a standard term like "iris," "clock wipe," or "push," you're going to have to describe more specifically what you are trying to do.
  3. Looking to create a video like the A-Team so have a picture to blend into the next but with being shot at revealing the next image so I can time it with the gun shots in the A-Teams theme.
  4. Can you link us to a sample video of what you want? Because what you describe sounds like a cross fade but that would be too simple.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  5. Do you mean animating the individual hits into an A-shape and then dissolving to the action?
    You can create int on any basic NLE -- Vegas Movie Studio, AviUtl. Even better would be something like After Effects. If you're looking for a play-and-go I don't think you're going to find it.
    https://forums.creativecow.net/thread/2/888473
  6. Just random bullet hole effect, not an "A"
  7. Banned
    Oct 2014
    Northern California
    So you mean you want a bullet-hole PNG transparency where the center is transparent so that you can overlay it in an NLE and show a new video inside? Perhaps enhanced with a shotgun effect and eventually the PNG zooms in until the new video is full screen?
  8. Well when you put it like THAT
  9. Banned
    Oct 2014
    Northern California
    Possibly enhanced with the Bonanza Burning Map effect?
  10. Just bullet holes as its more a military type vid
  11. Just add bullet holes sequentially (dozens are available as graphics) or unmask them sequentially, then cut a mask to reveal your underlying image. Simple in Vegas Movie Studio as mentioned before, easier and more control in After Effects.
