So I'm new to ripping DVDs and a few months ago I decided to rip my entire collection of tv and movies to an external hdd and hook it up to my Xbox one. I've noticed a problem with my Nickelodeon DVDs. For example. I have TMNT season one, it's about 12 episodes but when I try to rip it and select the files there are around 100 files on each disk. I know the eps are about 24 minutes but there are probably 50 files that length. There is another file that's around 3 hours, assuming that's the entire disk in one file I tried that but that file is fragments of the entire season out of order. The same thing happened ripping spongebob season 8. Anyone have any help? I've ripped house and the walking dead, both are very straight forward.
Thanks in advance for any help.
Results 1 to 19 of 19
The program is "WinX DVD Ripper Platinum". Is there one that works better? Hate to buy another and have the same issues.
Report back with your results. With DVD's you can save the main movie or episodes to individual .mkv files and you can select
which subtitle and audio streams you want. It will automatically add the chapter markers if present. -
You shouldn't have bought that one. From your description it can't handle the kind of advanced copy protection that DVDFab HD Decrypter can.
7 seconds? What player are you using? If you want .avi they'll need to be remuxed.
As manono said there is DVDFab HD Decrypter. Another good choice.
I downloaded fabdvd, it asked me to reboot so I did, then it said my trial expired??
Didn't know they did that now. I bought my lifetime license years ago for that product and haven't had any problem with that.
If this is a recent DVD release it may be encrypted with RipGuard or ARccOS which can be an issue with some rippers. I personally
haven't had a problem with that since 90% of what I do is Blu-Ray anyway. -
The decrypting part is free. It's the rest (the transcoding section) that has the trial. From the description on the DVDFab HD Decrypter page on this site:
It'll decrypt the entire DVD. To separate out the episodes once it's on the hard drive maybe use PGCDemux and have it create VOB files of all of them. Or use some program capable of choosing episodes for reencoding. I don't believe you've mentioned the intended final format.NOTE! The decryption, DVD to HDD and Blu-ray to HDD, is FREE, if you want more features then it's a trialware.
Buying new dvds or used dvds?
By Mr.Delusional in forum Off topicReplies: 2Last Post: 15th May 2015, 02:14 -
Poor sound when trying to play DVDs and Blue Ray DVDs on my computer
By peterjh in forum ComputerReplies: 9Last Post: 26th Dec 2012, 11:13 -
Episodic DVDs: is it possible...?
By Instant Martian in forum Authoring (DVD)Replies: 28Last Post: 30th Oct 2011, 14:23 -
How many DVDs do you own?
By tgpo in forum PollsReplies: 56Last Post: 19th Dec 2010, 23:32 -
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32
