Results 1 to 14 of 14
    Feb 2009
    Iran, Islamic Republic of
    Hi
    I have a subtitle in Persian language.
    I convert SRT subtitle to SUB IDX with txt to sub software.
    But the result subtitle is not smooth.
    when i watch movie with SRT subtitle the subtitle is smooth but with SUB/IDX the result is not good.
    Please tell me a way that i can make subtitle in SUB/IDX format with smooth edge subtitle.
    Thank you so much
  2. IDX/SUB tends to be "pixelated" especially in SD - not so much in HD. Did you use anti-aliasing?
    Have you considered hardcoding? And why IDX/SUB? You appearently can play the SRT. Could you use PGS if it has to be image based?
    Feb 2009
    Yes, exactly its pixelated.
    How i can use it on HD?
    How I do anti aliasing but result is same
    please help me as soon as possible.
    Feb 2009
    I use SUB\IDX because persian language is problem in palying in palyer.
    Most of the player can not play SRT subtitle in persian language.
    And most of them can not use best persian fonts.
  5. Okay. The sure solution would be to hardcode the subtitles. They'll be smooth as with SRT and can be used in all players. There will be a minor loss in video quality but try encoding a couple of minutes and see if you find it noticable
    You could use Vidcoder. Save your SRT as UTF-8 - see post #32. You select to encode a couple of minutes in the top of the Vidcoder window.
    An example
    Feb 2009
    I have to play videos through patriot box office media player.
    It's have problem with Persian Unicode UTF 8 subttile.
    Feb 2009
    The problem with your solution is about to convert video format.
    For sample, I add a MKV video but its try to encode it to MP4
    Then Its take too long time and ...
    Feb 2009
  9. but its try to encode it to MP4
    You can select MKV as well .. but it take just as long time.
    I found this manual. According to it (page 18) it should support UTF-8 SRT? Anyway, it also says it supports ASS. Did you try that?
    Feb 2009
    Originally Posted by roma_turok View Post
    Did you try create SUB IDX with Subtitle Edit?
    Hi
    Which subtitle type in save as make sub idx format file?
  11. File -> Export -> VobSub
    but first try save and play ASS type files as videobruger suggest
    Feb 2009
    Hi
    I create sub/idx file but its depend on video size on place of subtitle.
    How i can set subtitle create default independent of video size?
  13. Export with video size to 1080p and Border style to 3
    Check on you player with different size of videos
