can anyone tell me how i can compress a movie on dvd r in windows movie maker and is there anyway to speed up dvd maker encoding ??
i don't know how to use avs dvd either so plaese let me know how to do it with movie maker - thank you in advance
Closed Thread
Results 1 to 9 of 9
Well, basically it may be possible to fit the video. But the result won't be satisfying.
You'll have to calculate an average bitrate.- A DVD+R has a nominal capacity of decimal 4.7 billion bytes, equal to 37.6 billion bits (8 bit = 1 byte).
- 6 hours are equal to 21600 seconds.
- Dividing both returns an average bitrate of about 1740 kbps for everything (video and audio and some container overhead).
Now ... Movie Maker is among the tools I never used, I can't tell you how to use it optimally. I hope you will get some more advices...
Remember this thread? https://forum.videohelp.com/threads/373111-how-do-i-fit-6-hours-of-dvd-using-windows-dv...76#post2401476
Windows Movie Maker creates DVDs using Windows DVD Maker. You are already aware that Windows Movie Maker won't allow more than 2.5 hours of video per DVD. Why would you think that would magically change if you access it with Movie Maker? The only way to speed up Windows DVD Maker is to use a faster PC.
A friendly word of advice: Posting the same or very similar questions in multiple threads as you have been doing recently is against forum rules. Just add to your existing thread if you have more questions in the same vein.
Windows Movie Maker, on its own, will produce rather WMV files instead of "DVD Video"; this result won't be playable by a "legacy" DVD player. WMV may look a bit better than MPEG-2 in DVD Video at the same bitrate. Still, it will reduce the details a lot (similar to DivX 3).
memphis77, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in: https://forum.videohelp.com/threads/373111-how-do-i-fit-6-hours-of-dvd-using-windows-dv...76#post2401476
Moderator redwudz
Windows Movie Maker
By dfs4 in forum EditingReplies: 2Last Post: 27th Nov 2012, 10:06 -
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
Help with Windows Movie Maker Burn ?
By MLOR in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2011, 08:14 -
Windows Live Movie Maker: I can't figure out how to get it onto a DVD.
By chelsey_allen in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2011, 08:11 -
Widescreen in Windows Movie Maker?
By INEEDHELP423 in forum EditingReplies: 1Last Post: 27th Sep 2010, 01:48
