Hey, all. I've been having some major issues here. I'm trying to record my PS2 with the HDPVR 2 (using component cables). I can get the preview up and running just fine, however, I can't seem to find a solution for outputting to my TV. The issue seems to be that my HDTV and monitor just can't use low signal being sent through through the HDMI ("Not Supported Mode" showing on both tv and monitor). Does anyone know of any sort of work-around to this? It seems odd that the HDPVR would be component-capable, but not able to use HDMI passthrough to see the footage on a TV.
There is a video tutorial on YouTube that might help you: https://www.youtube.com/watch?v=-OVx55dZ54w
There are two setup details in particular that you might have missed. One, the PS2 should be set up to output YPbPr over component rather than RGB. Two, in passing the video's creator mentions a firmware update from Hauppauge. Have you updated the drivers to the latest ones? -
Many TVs don't accept 480i input on HDMI. And most computer monitors don't accept 480i.
I misunderstood some things in your original post, and I agree that jagabo is probably correct.
I am afraid I don't have any helpful advice with respect to TVs. Even if you do get a recommendation, it won't help unless the TV in question is a current model because things can change so much within product lines from year to year. I was going to suggest that you look at the manuals for new TVs which are selling at a good price, but when I looked at manuals that I have downloaded for a few of the TVs in the family, none indicated whether or not the TV supports 480i over HDMI.
I was also going to suggest trying a good component video distribution amplifier, to feed component video to both the TV and the HD-PVR 2 at the same time, but it has an internal buffer. I can't say if the buffer introduces an unacceptable delay.Last edited by usually_quiet; 25th Jul 2015 at 18:08. Reason: clarity, typo
Hauppague HDPVR2: Is it working? Best I can do? Any input appreciated :)
By ThanksInAdvance in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 21:06 -
Hauppauge HDPVR2 - No Video (HDMI) on ShowBiz
By dmacgreg37 in forum Capturing and VCRReplies: 12Last Post: 6th Jan 2015, 06:43 -
HDPVR2 won't capture 5.1 audio via HDMI
By kkiller23 in forum Capturing and VCRReplies: 6Last Post: 18th Oct 2014, 12:13 -
looking for help testing new HDPVR/HDPVR2/Rocket application
By sub3 in forum Capturing and VCRReplies: 19Last Post: 24th Aug 2014, 15:02 -
HDPVR2 and PS2
By Bizkit047 in forum Capturing and VCRReplies: 2Last Post: 21st Oct 2012, 15:40
