  1. Hi, Everyone
    May i know how to burn 2 movies to 1 bd disc that create BDMV and CERTIFICATE FOLDER?
    I had tried and added 2 mkv files using TSMUXER using BD FOLDER or BD ISO but the disc won't play on a Bluray Player that contain a BDMV and a Certificate Folder. However, I have no problem burning only 1 movie.
    I know that there is something to do with the clips numbering of the movie in order to make the Bluray Player plays the movies but how?
    Thanks a lot for your reply.
    Lee
    Feb 2014
    QUÉBEC
    you cant do this with tsmuxer.
    But try Bd-rebuilder or Multiavchd.
  3. Thanks a lot for your reply.
    I had tried the BD-Rebuilder to import the MKV file to re-encode the video but there are some problems, the video will pause a few times and the video was not running smooth and it had taken so many hours to re-encode the video.
    My original file resolution is 1920 X 800 and after conversion the resolution is 1920 X 1080 and it plays on the Bluray Player.
    May I know what is the problem that cause the video to pause in certain scenes?
    By the way, how to use BD-Rebuilder to create 2 movies in the BDMV and Certificate folder? Is it possible?
    Thanks a lot for your reply again.
    Lee
    Feb 2014
    QUÉBEC
    when you import mkv, instead of selecting one file, select two or more ??..
    you can also just take the bluray structure in your ''IMPORT'' folder , Just delete the ''PSEUDO'' folder, and burn it
    (no need to re-encode if your player can play non compliant blurays (1920X800).
