Results 1 to 9 of 9
    Mar 2015
    melb
    I can access any discs only from fresh restart, after I open drive, any disc I put in won't show up in my computer and all programs will see the drive as empty. Except anydvdHD which can see the volume label & still back up.
    I did try swamping the sata cable & also mobo sata ports but it still does it. A new BD-R writer later & it still does it.
    My motherboard is old & I can't find any refurbished, any ideas on a possible fix in the os?
    my specs: gigabyte p55, 4gb ram, vista ultimate 32-bit, don't know if any more specs or anything are needed.
    thanks
  2. What if you open the drive in Windows Explorer (right click on it and select Explore or something along those lines) and then use the View/Refresh menu (or CRTL+R), or if you can't open it by right clicking, try left clicking on the drive to select it and then refreshing.
    Mar 2015
    melb
    When I try that, it opens the drive & asks for a disc. Tried what you suggested, doesn't work.
    With this problem, the drive icon in my comp sees a disc, its different icon toi when no disc is in drive, but still can't access anything.
    Dec 2005
    Canada
    This mentions the missing drive problem.
    https://support.microsoft.com/en-us/mats/cd_dvd_drive_problems
    Feb 2004
    Australia
    Not knowing how long since os was reinstalled cleanly then use this link from ms
    Includes upper and lower filter issue in registry.
    Mar 2015
    melb
    Thanks all, seems to work, Ill give it some time to see in a few weeks.
    Mar 2015
    melb
    Deleting the upper & lower filters worked up until now. But the lower filter entry comes back.
    Would this be some program causing this? Anyway to find out?
    Dec 2005
    Canada
    IIRC ImgBurn lists the filters and programs under the 'Tools' tab.
    Mar 2015
    melb
    So far everything is unknown, but I seem to have found what causes this. It seems to happen when I already have WMP open, soon as I close it, the disc is my computer is recognized & autoplay loads up.
    Not sure why or what it means.
