  1. please can someone help Me,
    I see in the help files that using toolame for the sound encoding does a better job then TMPEnc itself, so no problems. I have downloaded a gui, only to find out that I have to get toolame.exe on My system before it will work.
    No problems , however, all I get is a compressed file with a whole bunch of c code and I cant seem to find the actual program itself
    can someone please help Me, the link given in the software section here is broken for toolame, and the http://www.flexion.org/audio/toolame/ doesnt work either
    anyone know where I can get it, or am I looking for the wrong thing? lol
    catch ya round and thanks
    The Hellsing family will purify this world...
    Feb 2001
    Berlin, Germany
    http://www.doom9.org/Soft21/Audio/toolame-02i.zip
    TMPG's weak point is actually the downsampling routine. Get an external Sampling frequency converter too.
    http://www.doom9.org/Soft21/Audio/ssrc-1.29.zip
  3. ty for the help, but now i need to ask how do i use the toolame file i downloaded, there isnt an .exe file in there anywhere?
    there is an .exe file for the frequnecy sampler, but im not sure where to go to setup its usage.
    ty for your help again
    Feb 2001
    Berlin, Germany
    http://www.doom9.org/software2.htm#audio
    There isn't an .exe file?
    First off there are ( at least) 3 ways to use toolame and ssrc these days.
    Basicly toolame and ssrc are command line based tools.
    Open the commandline console, change to the toolame dir and type "toolame --help" to see all options.
    Also you can use both tools with TMPG as external tools.
    http://www.doom9.org/mpg/toolame.htm
    3rd way is to use BeSweet (commandline based, GUI available), At the toolame tab resp. ssrc tab of the besweet GUI you can work with toolame.exe resp. ssrc.exe.
    If you use besweet.exe itself you will work with mp2enc.dll (toolame) and ssrc.dll.
    Totally confused?
    http://www.doom9.org/ac3tomp2.htm
    http://dspguru.doom9.net/
  5. hey totally kewl , thank you so much for the help, and the info
    I have toolame and sscr up and running as external tools, and now for the first time , i actually have made a vcd that plays in stereo not just the left speaker.
    now the next thing is, if you have time , how do i make the video a full screen and not have the black border at the top and bottom of the screen?
    I use TMPGEnc
    if not thanks heaps for the help so far
    Feb 2001
    Berlin, Germany
    I think video arrange method "No margin [keep aspect ratio]" is what you are looking for. TMPG > setting > advanced. Hell, you will lose a lot if you convert a widescreen to 4:3 without borders.
  7. after a short test i see what you are talking about, when you say i will lose a lot in conversion lol
    ok next question, how do i take a widescreen divX movie and manage to make it a fullscreen with no borders and no loss in VCD format?
    is it possible? or even practicle ?
    thanks for your help
