I'd like to make my (region-2) Sony BDP-S590 BlueRay player region-free. From what I've read certain "One for all" remotes are being used and my guess is that the key is having the "Magic" button, but I'm not sure.
More to the point: does anyone know if the One for all Smart Control URC-7960 will be suitable for making the S590 region-free? According to this thread the above remote has been successful in making a Sony BDP S-360 and BDP-S370, but I'm not sure if this means it'll work with all Sony BlueRay players (except those with region-1).
You've no doubt seen this thread as well:
https://www.videohelp.com/dvdhacks/sony-bdp-s590/11873
I'm sure folks have tried your proposed method. -
I've unlocked several Sony RC2-devices over the years, and all of them accepted the same codes to unlock. I didn't have to re-assign any codes to buttons on my remote, just had to press the same sequence of buttons once more. I'm not sure I used exactly an URC-7960, but from memory, mine looks very much like one.
Keep in mind that only the DVD-part of the player can be unlocked with a remote hack. -
I don't think there is any more information we can give you at this stage, and nobody will be able to confirm your conclusion.
If you want proof, go out and start buying programmable remotes, try them on your device that might be unlockable and see what happens. If I were you I'd go for a model of remote that has been successfully used to unlock (other) Sony devices. It's your best shot. -
Good advice. I have read that the URC-7960 has successfully been used to unlock other Sony BDP-S series Blueray players, and since it's a nice replacement for up to 6 remotes it won't be a total waste anyway, so I think I'll go for it.
Blu-Ray Sony BDP-BX320 Region Free Question
By jshaye in forum DVD & Blu-ray PlayersReplies: 9Last Post: 30th Dec 2014, 09:12 -
SONY BDP-S790 Region Free
By TomRz in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Apr 2013, 22:06 -
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Sony BDP-BX58 region free hack
By rami.flam in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Nov 2011, 19:42 -
Hi Sony BDP-S270 Hackin Free Region. PLEASE How Can I Do it???
By arcangel2010 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Aug 2011, 20:22
