I don't use command line. Have you tried the logical /stop and /stoppos ?
And I seem to recall it has a start and stop associated with the repeat function, so those commands for that. Or it's only intended to choose the start and play and then continue to the end of the file.
In any event, I've not used it that way.Google is your Friend
Cannot play .avc in mpc-hc 64 bit
By rogeiro in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2015, 02:50 -
MPC-HC will not play anything except mp4 container
By DUDERANCH in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2013, 21:17 -
Rotate Play Bluray Source with MPC
By moh3en in forum Software PlayingReplies: 1Last Post: 17th Feb 2012, 07:06 -
Lagarith won't play in MPC or WMP
By mst in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2012, 19:29 -
Using MPEG-2 Splitter to Play DVDs in MPC
By edger in forum Software PlayingReplies: 0Last Post: 30th Sep 2010, 23:51
