I have tried using DVD Rebuilder to shrink a particular DVD folder. I have it set to HC Encoder Mode, and have the HC Encoder options set to "Best".
This has already worked without a hitch for numerous other DVD folders, but for this particular one, it always stops at 5.7%. There is no error message, and the program gives no indication that it is stopping or finishing. But the encoding process doesn't progress beyond that point, even if I leave it there overnight. The last message in the Status Window is always "Creating M2V for VTS_01 segment 5".
I have tried running the DVD folder through several programs (such as FixVTS), then encoding the resulting folder with DVD-Rebuilder, but to no avail. I get the exact same result, down to the exact percentage.
There doesn't seem to be anything wrong with the DVD folder when I play it with VLC or run it through a program like DVD-Shrink. It's only when I try to encode it with DVD-Rebuilder that I run into this problem.
Results 1 to 16 of 16
Where did source come from and what other tasks where done prior to dvd rebuilder ?
Stalled generally means an error in source or low disk space. -
Ripped from disc with DVD-Shrink (but without any shrinking). No processing or conversion was done on the initial folder (although, as I stated in the OP, I did try running processes on it with such programs as FixVTS after the initial failure of DVD Rebuilder to no avail (I did not, however, alter the original DVD folder).
You do realize that shrink hasn't been updated in years and can't handle modern protection schemes. Your folder might have some protective scheme still left in it
Didn't work. DVD Rebuilder still stops at 5.7% on the resulting folder.
Could be. The discs are fairly old (from 2007), so maybe something went wrong on the first disc. It's rather odd that VLC, DVD-Shrink, etc, don't show any problems with it, though.
Players can skip over errors, sometimes you see a glitch, sometimes you don't.
Encoders can't do this, they need all the data to work with
Burn video to DVD with DVD Maker it keeps stopping 3/4's
By nancyjahn in forum Authoring (DVD)Replies: 1Last Post: 2nd Aug 2013, 12:32 -
Handbrake keeps stopping encoding at under 10% - what's going on?
By tuprox in forum DVD RippingReplies: 10Last Post: 25th Dec 2012, 17:54 -
Media Files Keep stopping
By niteghost in forum MediaReplies: 4Last Post: 20th Aug 2012, 18:37 -
Burned Divx movies stopping before end...
By Jeffross1968 in forum DVD RippingReplies: 9Last Post: 18th Feb 2012, 12:08 -
DVD Rebuilder overflow
By RickyPinxt in forum Video ConversionReplies: 14Last Post: 27th Apr 2011, 15:43
