I've recently learned how avisynth works and I have a video that I want to clean up and restore. I'm not 100% sure on what scripts to use for some of the aspects that need to be fixed, and needing a second opinion, wanted to know what type of scripts others would recommend.
These are a few samples
https://www.sendspace.com/file/a5961r
https://www.sendspace.com/file/hz0zu2
http://postimg.org/image/swxowvg5f/
http://postimg.org/image/516udsduz/
http://postimg.org/image/gni902jy5/
Welcome.
Your two mp4 samples look like re-encodes from VHS captures. You can play with color, levels, some of the noise, but the severe line timing errors and shimmer can't be repaired. Those problems can be "fixed" only by capturing with a better VCR and a line-level tbc. In any case, don't expect great results working from very low bitrate lossy re-encodes with bad compression artifacts. They've been deinterlaced and half of the data was thrown away, which doesn't help. Some of it looks like it was originally film source (telecined) and incorrectly dinterlaced. No fix for that.
The images have obvious problems, but what could be done with them depends on the condition of adjacent frames. Still images don't have adjacent frames.
- My sister Ann's brother -
These clips are where the pics are taken from
https://www.sendspace.com/file/u1z7gy
https://www.sendspace.com/file/zwdem1
https://www.sendspace.com/file/yke7i7 -
You're trying to clean up a video transfer of a workprint! Not only is the color timing (predictably) off to begin with, they've then gone and marked it up with grease pencils and sharpies! Don't expect miracles.
Is this a joke? 432x304 MP4? I take it you didn't capture these yourself? And are you prepared to go over them several times, scene by scene, frame by frame?
432x304 = 1.42:1...and you can tell the mp4's were cropped earlier: borders are clean but the image inside has wiggle-itis.
I'd ask the same question. Seriously, these vids are wrecked. Whoever did it made the most common 100 mistakes and invented 100 more. Maybe they were intermediate working samples that were discarded? Are you sure you want to try this? Promise, the results won't be big improvements, and you're almost down to frame by frame, as manono pointed out.- My sister Ann's brother -
Even if it won't be the best quality, if having to go frame-by-frame with it several times the only way to go, I would just work with the exclusive content on it which make up about 20 min of it. But if it's that bad, I have other videos you could maybe take a look at and let me know if their fixable or not.
https://www.sendspace.com/file/j1344p this is originally a 704x480 mkv changed to mp4 for uploading, with the full video having up to 10 min of exclusive scenes
https://www.sendspace.com/file/63pk5c same content, from DVD version I own
https://mega.co.nz/#!hMpzgTyA!uxf3FBiLulvk6ZT5OcN42-8iYgOn-yGHo_D5V8EA7bQ this is from a PAL DVD
AviSynth's MeGUI: how to queue multiple scripts at once?
By Freodon in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2015, 08:06 -
Problem using AviSynth scripts with MeGUI
By yaston in forum Video ConversionReplies: 6Last Post: 5th Oct 2014, 23:24 -
Error opening Avisynth scripts in VirtualDubMod
By farklem in forum DVD RippingReplies: 4Last Post: 3rd Apr 2013, 17:53 -
how to remove logo by avisynth scripts and filters?
By poluhale2 in forum EditingReplies: 15Last Post: 8th Oct 2012, 09:31 -
VHS to DVD Restoration. Best AviSynth scripts?
By VideoFanatic in forum RestorationReplies: 47Last Post: 25th Oct 2011, 07:34
