I have just recently decided to D/L DivX movies off of the net. I had decided to try and burn one. Encoding went succesfuly and I went ahead and burned it. Few troubles at first as the disk would not play, so i tried again with another disk. After a few tries with this disk i managed to get it to work, however it was really really laggy. I managed to get it to work 3 times so i knew it wasnt a one off. So i decided to burn it again on a 2x instead of a 4x. I went to play this disk and now neither of them work, it keeps coming up with the "No Disk" error. So i tried some of the methods that have been talked about, but still no luck. So does anyone else have any ideas that have worked for them?
I got an idea for you!
That DVD player isn't CD-R or CD-RW compatiable! lol"If hustling is deviance in the eyes of the lord, then in my realm he is blind"...B*Tip - Back in the day! -
Well the above is true, it isn't compatible by spec, but if you can find some Princo or Vivastar CDRs, they should work.
Originally Posted by Dj_Void
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 20:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 19:59 -
LG LDA 511 turns off in the middle of a movie!
By Wantonmaya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Oct 2008, 16:56 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
