I've used the free DVDFab HD Decrypter to rip my DVDs for years, but it is having trouble reading the DVDs for the first time. I have the newest version (9.2.0.4). With some of my DVDs, Decrypter tries to read them for a minute but then gives me a message that I have to pay for an upgrade. None of these are new DVD releases either ... the DVDs giving me trouble range from 1-15 years old. Other similar DVDs just spin without ever being recognized. Has something changed? Or is there a better free DVD ripper now? Thank you!
Results 1 to 12 of 12
... the message I get with many DVDs now is that I need to "buy or renew DVDFab "DVD Copy" or you can wait for new version of DVDFab HD Decrypter." This is not with new DVD releases though. For example, I just got this message with Cars 2 from 2011.
I just wanted to add my 2 cents worth.... I too have been having troubles with DVDFab of late. And I'm talking about DVD's from early 2002 era. I tried the suggestion above, and makemkv solved all my issues... I will definitely consider buying it if this continues. Although am a bit irked if after spending $50 on DVDFab I now need to spend another $50 on a different piece of software yet again.
But I do suggest trying it while its free in bata... -
have you tried uninstalling and going back to an older version
if a program works is not corrupted or malware, i keep the DL
i can always go back to an old version of any program
even old ver of Firefox
just like always keep your source files, backup ..backup..backup
BTW thanks for the makemkv suggestion
i DL it and will try it out.. just in case i ever need it
i am not fond of MKV files, but having options is Always good -
Vlc player rips dvds, has a built-in decrypter. I have used a giveaway version of magic dvd copier, version 7. It works great for making a copy of the movie. I have moved on to magic dvd ripper, which gives me mp4 files. Here's a link to magic dvd copier http://www.thinstallsoft.com/magic-dvd-copier-portable/
i was not referring to updated encryption
the OP says the new version of decrypter will not decrypt OLD discs
i was referring to old versions of decrypter NOT Dfab
isn't Decrypter the free in the background process
NOT like Dfab which has all the ripping and cloning options -
You didn't say in your post anything about the older dvd decrypter and the op said nothing about that,just about dvdfab decrypter to which i was referring to.
well pardon me
the advice still stands
if the new version refuses to work on old discs
then use an older version
its plain stupid of the software creator, to create a malfunction by leaving out coded processes that work on older dvd's -
I have the lifetime DVDFab suite and I paid for MakeMKV from the author - both work well for me for my backups. For most DVD's that I really want to make a DVD I still use DVDShrink which seems to work well with any title released in Australia - maybe they don't bother with "advanced" encryption down here? I mostly use MakeMKV to transfer the movie onto my NAS..
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I've seen this problem a few times since buying a new machine (with a new DVD drive).
Going back to the old machine and ripping the problem DVD has always worked, suggesting the drive or its firmware may be an issue?
DVDFab HD Decrypter no longer free? (it is/solved)
By justinrye in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2014, 18:21 -
I can't access the free DVDFab HD Decrypter anymore - Why?
By JohnnyBob in forum DVD RippingReplies: 25Last Post: 16th Mar 2014, 18:36 -
[Resolved] Question about DVDFab HD Decrypter (Free Edition)
By Quamatek in forum Newbie / General discussionsReplies: 23Last Post: 4th Jan 2013, 01:09 -
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 14:28 -
What happened to DVDFab HD Decrypter free??
By chowmein in forum DVD RippingReplies: 9Last Post: 22nd Oct 2010, 21:18
