Not sure how definitive, but mediainfo detects the RGBA color space in this Lagarith clip.
General
Complete name : D:\ScreenCap\RX_RGBA.avi
Format : AVI
File size : 84.2 MiB
Duration : 19s 958ms
Overall bit rate : 35.4 Mbps
Writing library : This file was made by Adv.Editing AVI/BMP Export (RGBA).
Video
Format : Lagarith
Codec ID : LAGS
Bit rate : 35.4 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 24.000 fps
Color space : RGBA
Bits/(Pixel*Frame) : 1.600
Stream size : 84.2 MiB (100%)Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thanks. But this MOV doesn't have a ColorSpace line in MediaInfo like yours:
General
Complete name: C:\Docs\My Videos\Misc Video\AlphaChannel\PSY Alpha Channel Template 2 - Dancing (No Feathering).mov
Format: MPEG-4
Format profile: QuickTime
Codec ID: qt
File size: 4.49 MiB
Duration: 1s 333ms
Overall bit rate mode: Variable
Overall bit rate: 28.2 Mbps
Encoded date: UTC 2012-11-05 19:33:32
Tagged date: UTC 2012-11-05 19:33:32
Writing library: Apple QuickTime
Video
Format: PNG
Format/Info: Portable Network Graphic
Codec ID: png
Duration: 1s 333ms
Bit rate mode: Variable
Bit rate: 28.2 Mbps
Width: 375 pixels
Height: 760 pixels
Display aspect ratio: 0.493
Frame rate mode: Constant
Frame rate: 23.976 fps
Compression mode: Lossless
Bits/(Pixel*Frame): 4.125
Stream size: 4.48 MiB (100%)
Language: English
Encoded date: UTC 2012-11-05 19:33:27
Maybe the PNG here is the indicator? -
The presence of an alpha channel indicated by various programs might just be a "dummy" alpha (it's there for memory alignment purposes, not valid data). Presumably you don't care about that
So the only definitive way to know for certain if it's a valid alpha channel is open it up and look at the alpha channel. You can do that in various compositing applications, some NLE's .
For some types of formats, there are different alpha interpretations e.g. prematted vs. straight alpha - so what you see might depend on how you have it set up -
Sorry Terry, I was responding to your second post specifically mentioning mov, didn't read the first one as closely, I guess.
FWIW, I just exported a Lagarith avi with an alpha channel from After Effects. Quicktime player couldn't open it -- missing component -- but it still correctly identified the color space as Millions+. Not as simple as Mediainfo or Gspot obviously, but it might help. -
Thanks both. Guess the best way then is to simply import it into my NLE, MAGIX Movie Edit Pro 2014 Premium and take a close look.
ALPHA Channel videos - use in Nero 15
By Clark711 in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2014, 22:18 -
What bit depth(s) can a video that has an alpha channel have?
By moonman239 in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2014, 16:46 -
Problems with Alpha Channel
By CKyle in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 17:02 -
Good compromised codec with alpha channel
By elmuz in forum EditingReplies: 6Last Post: 17th Sep 2010, 11:07 -
VP6a encoding / video with alpha channel
By GRUMBLE in forum Video ConversionReplies: 2Last Post: 26th Aug 2010, 05:08
