hello!
how can I remove the audio from mp4 video files?
an easy way please! fastest with one click and without bloated software!
thanks!
Wow, I'm not sure, I just assumed an MP4Box gui would work much like the MKVMerge one...
Yamb is just as bad.
I guess you're stuck with the command line which is all I've ever used...
Ummmm... What other muxers are there? -
use avidemux, drag and drop the file. Then go to audio (on the top of the screen), select track, and deselect "enabled"
here is a picture of the gui
change the output format at the lower left to mp4 then click the blue disk on top to saveLast edited by ezcapper; 18th Jul 2015 at 18:11.
e.g. yamb beta 2 . Make sure you download the 2.1 version, not the 1.6
https://www.videohelp.com/download/Yamb%202.1.0.0%20beta%202.zip
0) First setup the path of mp4box.exe by pushing settings , advanced settings, then in the location box, select mp4box.exe
1) double click create MP4
2) push add button, select your mp4 (or just drag the mp4 to the creation window)
3) UNcheckmark the audio stream, leaving the video stream checkmarked
4) In the output box, select the output path and file name
5) Push next
How to remove subtitles from MP4 file?
By Caspoor in forum SubtitleReplies: 11Last Post: 15th Sep 2014, 13:51 -
How do I remove blur from my MP4 file?
By JaneHarris in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2013, 12:06 -
How to remove hard sub from mp4?
By Choey in forum SubtitleReplies: 5Last Post: 4th Sep 2013, 13:00 -
Easy way to take subtitles from .mkv to .mp4?
By InfiniteZr0 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2011, 19:53 -
How to remove logo from an MP4 file?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2011, 06:20
