    Feb 2008
    Portugal
    How can I see and access files or archives that are not visible usually?
    Thanks for the help.
  2. In a windows folder, select view => options => show hidden files, folders, and drives
    Feb 2008
    Portugal
    Thanks poisondeathray.
    But I don't manage to view that window with FOLDER OPTIONS. ( Windows 7 )
  4. In Win7, it's Organize -> Folder and Search Options -> View. While you're there disable the Hide Extensions For Known File Types option. And disable Hide Protected Operating System Files -- if you want to see them. There are still some files that will be invisible, those in the System Volume Information folder.
    Feb 2008
    Portugal
    Thanks, Jagabo.
    Everything is OK!
