Hello,
I have ts files from DVB-T tuner (mpeg4). The output files obtained after cutting and conversion (by Avidemux) from ts to avi (or mp4 or ts) are markedly smaller than expected. I'm using copy mode to both video and audio streams. Is it possible? Are the commercials removed such a large volume?
Regards,
f.
Results 1 to 16 of 16
Yes it's normal. Transport streams typically have 4-8% higher overhead than containers like MP4, MKV. So even if you didn't edit it, it will be smaller if you used a different container
Also, they usually have other streams other than video and audio (metadata, subs, captions, descriptors), which you might have been discarded -
Thank you for answer.
Yes, I expected 10% higher overhead. Unfortunately (or maybe fortunately), the output files size is only 70% of input TS-file size. Is it possible? Are the metadata 20% of TS-file size?
Sample:
Original TS file (movie+commercials): 3.1 GB /2h36/
AVI (or MP4) (movie extracted): 1.5 GB /1h55/
AVI (commercials extracted) 0.7 GB /0h41/
Regards,
f. -
I suspect there were other audio and video streams in the original TS that were discarded (often you will have other language tracks for example)
Use mediainfo (view=>text) on the original, and edited file, then copy & paste the text report back here
You said you used "copy" mode by you could you have inadvertently re-encoded the video and/or audio ? -
Hello,
You have right - there is two sound paths, but the output file contains both. The text below is the output of Mediainfo.
Output file (movie only; avi container)Code:General ID : 2 (0x2) Complete name : /media/video2/DVBT/[TS]2014-10-05.12.45.07-TV6-60PrzyczajonyTygrys/000.ts Format : MPEG-TS File size : 3.10 GiB Duration : 2h 35mn Overall bit rate mode : Variable Overall bit rate : 2 853 Kbps Network name : EmiTel Wa Video ID : 702 (0x2BE) Menu ID : 25 (0x19) Format : AVC Format/Info : Advanced Video Codec Format version : Version 2 Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 27 Duration : 2h 35mn Bit rate : 2 260 Kbps Maximum bit rate : 0 bps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.218 Stream size : 2.45 GiB (79%) Color primaries : BT.601 PAL Transfer characteristics : BT.470 System B, BT.470 System G Matrix coefficients : BT.601 Color range : Limited Audio #1 ID : 703 (0x2BF) Menu ID : 25 (0x19) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 4 Duration : 2h 35mn Bit rate mode : Constant Bit rate : 256 Kbps Maximum bit rate : 0 bps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -1s 624ms Stream size : 285 MiB (9%) Language : Polish Audio #2 ID : 708 (0x2C4) Menu ID : 25 (0x19) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 4 Duration : 2h 35mn Bit rate mode : Constant Bit rate : 192 Kbps Maximum bit rate : 0 bps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -1s 656ms Stream size : 214 MiB (7%) Language : aux Language, more info : Visual impaired commentary Menu ID : 701 (0x2BD) Menu ID : 25 (0x19) Duration : 2h 35mn List : 702 (0x2BE) (AVC) / 703 (0x2BF) (MPEG Audio, Polish) / 708 (0x2C4) (MPEG Audio, aux) Language : / Polish / aux Service name : TV6 Service provider : EmiTel Service type : advanced codec SD digital television Maximum bit rate : 0 UTC 2014-10-05 00:30:00 : pl:Mega Chichot / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-05 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-05 02:00:00 : pl:I Like It - odc. 1 / pl:program muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-05 03:00:00 : pl:Istne szaleństwo - odc. 5 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-05 04:00:00 : pl:Rodzina zastępcza - odc. 287 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-05 05:00:00 : pl:Mega Chichot - odc. 29 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-05 05:30:00 : pl:Benny Hill - odc. 57 / pl:program rozrywkowy / leisure hobbies / / 00:35:00 / UTC 2014-10-05 06:05:00 : pl:Benny Hill - odc. 58 / pl:program rozrywkowy / leisure hobbies / / 00:40:00 / UTC 2014-10-05 06:45:00 : pl:Przyjaciele z Kieszonkowa / pl:serial animowany / cartoons/puppets / / 00:30:00 / UTC 2014-10-05 07:15:00 : pl:Pradawny ląd 6: Tajemnica jaszczurczej skały / pl:film animowany / cartoons/puppets / / 01:35:00 / UTC 2014-10-05 08:50:00 : pl:Mordercza pogoda / pl:film SF / science fiction/fantasy/horror / / 01:55:00 / UTC 2014-10-05 10:45:00 : pl:Przyczajony tygrys, ukryty smok / pl:film przygodowy / adventure/western/war / / 02:35:00 / Running UTC 2014-10-05 13:20:00 : pl:Ballada o Daltonach / pl:film animowany / cartoons/puppets / / 01:40:00 / Running UTC 2014-10-05 15:00:00 : pl:Cesar Milan. Przywódca stada - odc. 5 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / Not running UTC 2014-10-05 16:00:00 : pl:Ciekawość - s. I / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-05 17:00:00 : pl:Tajemnice i zagadki przeszłości - odc. 5 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-05 18:00:00 : pl:Włatcy móch - s. II, odc. 32 / pl:serial animowany dla dorosłych / adult movie/drama / / 00:30:00 / UTC 2014-10-05 18:30:00 : pl:La Maviuta - gender romance - odc. 5 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-05 19:00:00 : pl:Kacza dynastia - s. I, odc. 5 / pl:reality show / show/game show / / 00:30:00 / UTC 2014-10-05 19:30:00 : pl:Wrogie niebo - s. I, odc. 9 / pl:serial SF / science fiction/fantasy/horror / / 01:00:00 / UTC 2014-10-05 20:30:00 : pl:Życie na wybiegu - odc. 1 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-05 21:30:00 : pl:Zabójcze polowanie / pl:film sensacyjny / movie/drama / / 02:00:00 / UTC 2014-10-05 23:30:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 14 / pl:serial dokumentalny / education/science/factual topics / / 00:30:00 / UTC 2014-10-06 00:00:00 : pl:Włatcy móch - s. II, odc. 31 / pl:serial animowany dla dorosłych / adult movie/drama / / 00:30:00 / UTC 2014-10-06 00:30:00 : pl:Włatcy móch - s. II, odc. 32 / pl:serial animowany dla dorosłych / adult movie/drama / / 00:30:00 / UTC 2014-10-06 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-06 02:00:00 : pl:I Like It - odc. 2 / pl:program muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-06 03:00:00 : pl:Szósty zmysł - odc. 772 / pl:magazyn / news magazine / / 01:00:00 / UTC 2014-10-06 04:00:00 : pl:Szósty zmysł - odc. 773 / pl:magazyn / news magazine / / 00:50:00 / UTC 2014-10-06 04:50:00 : pl:Czarodzieje z Waverly Place - s. II, odc. 28 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-06 05:20:00 : pl:Czarodzieje z Waverly Place - s. II, odc. 29 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-06 05:50:00 : pl:Galileo - odc. 297 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-06 06:50:00 : pl:Rodzina zastępcza - odc. 287 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-06 07:50:00 : pl:Komisarz Rex - s. V, odc. 12 / pl:serial kryminalny / movie/drama / / 01:00:00 / UTC 2014-10-06 08:50:00 : pl:Frank i dżungla - s. III, odc. 6 / pl:serial przyrodniczy / nature/animals/environment / / 01:10:00 / UTC 2014-10-06 10:00:00 : pl:Miodowe lata - odc. 7 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-06 10:35:00 : pl:Miodowe lata - odc. 8 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-06 11:10:00 : pl:Miodowe lata - odc. 56 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-06 12:00:00 : pl:Rodzina zastępcza - odc. 288 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-06 13:00:00 : pl:Strażnik Teksasu - s. VIII, odc. 197 / pl:serial sensacyjny / movie/drama / / 01:00:00 / UTC 2014-10-06 14:00:00 : pl:Kosmos - s. II, odc. 13 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-06 15:00:00 : pl:Czarodzieje z Waverly Place - s. II, odc. 30 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-06 15:30:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 1 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-06 16:00:00 : pl:Miodowe lata - odc. 9 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-06 16:35:00 : pl:Miodowe lata - odc. 10 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-06 17:10:00 : pl:Miodowe lata - odc. 57 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-06 18:00:00 : pl:Galileo - odc. 298 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-06 19:00:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 1 / pl:serial dokumentalny / education/science/factual topics / / 00:35:00 / UTC 2014-10-06 19:35:00 : pl:Rów polarny / pl:film SF / science fiction/fantasy/horror / / 01:50:00 / UTC 2014-10-06 21:25:00 : pl:Amerykański yakuza / pl:dramat sensacyjny / movie/drama / / 02:00:00 / UTC 2014-10-06 23:25:00 : pl:Komisarz Rex - s. V, odc. 12 / pl:serial kryminalny / movie/drama / / 01:05:00 / UTC 2014-10-07 00:30:00 : pl:Rude Tube - s. I, odc. 6 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-07 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-07 02:00:00 : pl:America's Got Talent - s. VIII, odc. 6 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-07 03:00:00 : pl:Szósty zmysł - odc. 774 / pl:magazyn / news magazine / / 01:00:00 / UTC 2014-10-07 04:00:00 : pl:Szósty zmysł - odc. 775 / pl:magazyn / news magazine / / 00:50:00 / UTC 2014-10-07 04:50:00 : pl:Czarodzieje z Waverly Place - s. II, odc. 30 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-07 05:20:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 1 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-07 05:50:00 : pl:Galileo - odc. 298 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-07 06:50:00 : pl:Rodzina zastępcza - odc. 288 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-07 07:50:00 : pl:Komisarz Rex - s. V, odc. 13 / pl:serial kryminalny / movie/drama / / 01:00:00 / UTC 2014-10-07 08:50:00 : pl:Frank i dżungla - s. III, odc. 7 / pl:serial przyrodniczy / nature/animals/environment / / 01:10:00 / UTC 2014-10-07 10:00:00 : pl:Miodowe lata - odc. 9 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-07 10:35:00 : pl:Miodowe lata - odc. 10 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-07 11:10:00 : pl:Miodowe lata - odc. 57 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-07 12:00:00 : pl:Rodzina zastępcza - odc. 289 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-07 13:00:00 : pl:Strażnik Teksasu - s. VIII, odc. 198 / pl:serial sensacyjny / movie/drama / / 01:00:00 / UTC 2014-10-07 14:00:00 : pl:Kosmos - s. II, odc. 14 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-07 15:00:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 2 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-07 15:30:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 3 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-07 16:00:00 : pl:Miodowe lata - odc. 11 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-07 16:35:00 : pl:Miodowe lata - odc. 12 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-07 17:10:00 : pl:Miodowe lata - odc. 58 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-07 18:00:00 : pl:Galileo - odc. 299 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-07 19:00:00 : pl:Rude Tube - s. I, odc. 7 / pl:program rozrywkowy / leisure hobbies / / 00:35:00 / UTC 2014-10-07 19:35:00 : pl:Komando smoka / pl:film sensacyjny / movie/drama / / 02:25:00 / UTC 2014-10-07 22:00:00 : pl:Sekret mojej matki / pl:thriller / detective/thriller / / 01:55:00 / UTC 2014-10-07 23:55:00 : pl:Komisarz Rex - s. V, odc. 13 / pl:serial kryminalny / movie/drama / / 01:05:00 / UTC 2014-10-08 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-08 02:00:00 : pl:America's Got Talent - s. VIII, odc. 7 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-08 03:00:00 : pl:Szósty zmysł - odc. 776 / pl:magazyn / news magazine / / 01:00:00 / UTC 2014-10-08 04:00:00 : pl:Szósty zmysł - odc. 777 / pl:magazyn / news magazine / / 00:50:00 / UTC 2014-10-08 04:50:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 2 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-08 05:20:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 3 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-08 05:50:00 : pl:Galileo - odc. 299 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-08 06:50:00 : pl:Rodzina zastępcza - odc. 289 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-08 07:50:00 : pl:Komisarz Rex - s. V, odc. 14 / pl:serial kryminalny / movie/drama / / 01:00:00 / UTC 2014-10-08 08:50:00 : pl:Frank i dżungla - s. III, odc. 8 / pl:serial przyrodniczy / nature/animals/environment / / 01:10:00 / UTC 2014-10-08 10:00:00 : pl:Miodowe lata - odc. 11 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-08 10:35:00 : pl:Miodowe lata - odc. 12 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-08 11:10:00 : pl:Miodowe lata - odc. 58 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-08 12:00:00 : pl:Rodzina zastępcza - odc. 290 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-08 13:00:00 : pl:Strażnik Teksasu - s. VIII, odc. 199 / pl:serial sensacyjny / movie/drama / / 01:00:00 / UTC 2014-10-08 14:00:00 : pl:Kosmos - s. II, odc. 15 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-08 15:00:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 4 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-08 15:30:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 5 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-08 16:00:00 : pl:Miodowe lata - odc. 13 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-08 16:35:00 : pl:Miodowe lata - odc. 15 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-08 17:10:00 : pl:Miodowe lata - odc. 59 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-08 18:00:00 : pl:Galileo - odc. 300 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-08 19:00:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 2 / pl:serial dokumentalny / education/science/factual topics / / 00:30:00 / UTC 2014-10-08 19:30:00 : pl:Tajemnice i zagadki przeszłości - odc. 6 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-08 20:30:00 : pl:Jak skończy się świat - odc. 5 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-08 21:30:00 : pl:Mroźny wiatr / pl:horror / detective/thriller / / 01:55:00 / UTC 2014-10-08 23:25:00 : pl:Komisarz Rex - s. V, odc. 14 / pl:serial kryminalny / movie/drama / / 01:05:00 / UTC 2014-10-09 00:30:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 1 / pl:serial dokumentalny / education/science/factual topics / / 00:30:00 / UTC 2014-10-09 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-09 02:00:00 : pl:America's Got Talent - s. VIII, odc. 8 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-09 03:00:00 : pl:Szósty zmysł - odc. 778 / pl:magazyn / news magazine / / 01:00:00 / UTC 2014-10-09 04:00:00 : pl:Szósty zmysł - odc. 779 / pl:magazyn / news magazine / / 00:50:00 / UTC 2014-10-09 04:50:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 4 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-09 05:20:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 5 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-09 05:50:00 : pl:Galileo - odc. 300 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-09 06:50:00 : pl:Rodzina zastępcza - odc. 290 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-09 07:50:00 : pl:Komisarz Rex - s. V, odc. 15 / pl:serial kryminalny / movie/drama / / 01:00:00 / UTC 2014-10-09 08:50:00 : pl:Frank i dżungla - s. III, odc. 9 / pl:serial przyrodniczy / nature/animals/environment / / 01:10:00 / UTC 2014-10-09 10:00:00 : pl:Miodowe lata - odc. 13 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-09 10:35:00 : pl:Miodowe lata - odc. 15 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-09 11:10:00 : pl:Miodowe lata - odc. 59 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-09 12:00:00 : pl:Rodzina zastępcza - odc. 291 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-09 13:00:00 : pl:Strażnik Teksasu - s. I, odc. 1 / pl:serial sensacyjny / movie/drama / / 01:00:00 / UTC 2014-10-09 14:00:00 : pl:Kosmos - s. II, odc. 16 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-09 15:00:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 6 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-09 15:30:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 7 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-09 16:00:00 : pl:Miodowe lata - odc. 16 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-09 16:35:00 : pl:Miodowe lata - odc. 17 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-09 17:10:00 : pl:Miodowe lata - odc. 60 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-09 18:00:00 : pl:Galileo - odc. 301 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-09 19:00:00 : pl:Rude Tube - s. I, odc. 8 / pl:program rozrywkowy / leisure hobbies / / 00:35:00 / UTC 2014-10-09 19:35:00 : pl:Dziwna broń / pl:film dokumentalny / education/science/factual topics / / 01:55:00 / UTC 2014-10-09 21:30:00 : pl:Soldier Boyz / pl:film sensacyjny / movie/drama / / 01:55:00 / UTC 2014-10-09 23:25:00 : pl:Komisarz Rex - s. V, odc. 15 / pl:serial kryminalny / movie/drama / / 01:05:00 / UTC 2014-10-10 00:30:00 : pl:Włatcy móch - s. II, odc. 31 / pl:serial animowany dla dorosłych / adult movie/drama / / 00:30:00 / UTC 2014-10-10 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-10 02:00:00 : pl:America's Got Talent - s. VIII, odc. 9 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-10 03:00:00 : pl:Szósty zmysł - odc. 780 / pl:magazyn / news magazine / / 01:00:00 / UTC 2014-10-10 04:00:00 : pl:Szósty zmysł - odc. 781 / pl:magazyn / news magazine / / 01:00:00 / UTC 2014-10-10 05:00:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 6 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-10 05:30:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 7 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-10 06:00:00 : pl:Galileo - odc. 301 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-10 07:00:00 : pl:Rodzina zastępcza - odc. 291 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-10 08:00:00 : pl:Komisarz Rex - s. VIII, odc. 1 / pl:serial kryminalny / movie/drama / / 01:00:00 / UTC 2014-10-10 09:00:00 : pl:Frank i dżungla - s. III, odc. 10 / pl:serial przyrodniczy / nature/animals/environment / / 01:05:00 / UTC 2014-10-10 10:05:00 : pl:Miodowe lata - odc. 16 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-10 10:40:00 : pl:Miodowe lata - odc. 17 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-10 11:15:00 : pl:Miodowe lata - odc. 60 / pl:serial komediowy / comedy / / 00:45:00 / UTC 2014-10-10 12:00:00 : pl:Rodzina zastępcza - odc. 292 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-10 13:00:00 : pl:Strażnik Teksasu - s. I, odc. 2 / pl:serial sensacyjny / movie/drama / / 01:00:00 / UTC 2014-10-10 14:00:00 : pl:Kosmos - s. II, odc. 17 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-10 15:00:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 8 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-10 15:30:00 : pl:Czarodzieje z Waverly Place - s. III, odc. 9 / pl:serial familijny / children's/youth programmes / / 00:30:00 / UTC 2014-10-10 16:00:00 : pl:Miodowe lata - odc. 18 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-10 16:35:00 : pl:Miodowe lata - odc. 19 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-10 17:10:00 : pl:Miodowe lata - odc. 61 / pl:serial komediowy / comedy / / 00:50:00 / UTC 2014-10-10 18:00:00 : pl:Galileo - odc. 302 / pl:program popularnonaukowy / technology/natural sciences / / 01:00:00 / UTC 2014-10-10 19:00:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 3 / pl:serial dokumentalny / education/science/factual topics / / 00:35:00 / UTC 2014-10-10 19:35:00 : pl:Mroźny wiatr / pl:horror / detective/thriller / / 01:55:00 / UTC 2014-10-10 21:30:00 : pl:Soldier Boyz / pl:film sensacyjny / movie/drama / / 01:55:00 / UTC 2014-10-10 23:25:00 : pl:Komisarz Rex - s. VIII, odc. 1 / pl:serial kryminalny / movie/drama / / 01:05:00 / UTC 2014-10-11 00:30:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 2 / pl:serial dokumentalny / education/science/factual topics / / 00:30:00 / UTC 2014-10-11 01:00:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-11 02:00:00 : pl:America's Got Talent - s. VIII, odc. 10 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-11 03:00:00 : pl:Kroniki facetów z klasą - odc. 5 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-11 04:00:00 : pl:Rodzina zastępcza - odc. 292 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-11 05:00:00 : pl:Mega Chichot - odc. 30 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-11 05:30:00 : pl:Benny Hill - odc. 61 / pl:program rozrywkowy / leisure hobbies / / 00:35:00 / UTC 2014-10-11 06:05:00 : pl:Benny Hill - odc. 62 / pl:program rozrywkowy / leisure hobbies / / 00:45:00 / UTC 2014-10-11 06:50:00 : pl:Przyjaciele z Kieszonkowa / pl:serial animowany / cartoons/puppets / / 00:20:00 / UTC 2014-10-11 07:10:00 : pl:Ninjago - mistrzowie spinjitzu - odc. 9 / pl:serial animowany / cartoons/puppets / / 00:30:00 / UTC 2014-10-11 07:40:00 : pl:Ninjago - mistrzowie spinjitzu - odc. 10 / pl:serial animowany / cartoons/puppets / / 00:30:00 / UTC 2014-10-11 08:10:00 : pl:Ninjago - mistrzowie spinjitzu - odc. 11 / pl:serial animowany / cartoons/puppets / / 00:30:00 / UTC 2014-10-11 08:40:00 : pl:Ninjago - mistrzowie spinjitzu - odc. 12 / pl:serial animowany / cartoons/puppets / / 00:30:00 / UTC 2014-10-11 09:10:00 : pl:Przyjaciele z Kieszonkowa / pl:serial animowany / cartoons/puppets / / 00:20:00 / UTC 2014-10-11 09:30:00 : pl:Pradawny ląd 7: Kamień zimnego ognia / pl:film animowany / cartoons/puppets / / 01:35:00 / UTC 2014-10-11 11:05:00 : pl:Flicka 2 / pl:film familijny / children's/youth programmes / / 02:00:00 / UTC 2014-10-11 13:05:00 : pl:Cesar Milan. Przywódca stada - odc. 5 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-11 14:05:00 : pl:Ciekawość - s. I / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-11 15:05:00 : pl:Zabójcze kataklizmy - odc. 5 / pl:serial popularnonaukowy / technology/natural sciences / / 01:10:00 / UTC 2014-10-11 16:15:00 : pl:Miliony Baileya / pl:komedia / comedy / / 01:45:00 / UTC 2014-10-11 18:00:00 : pl:Włatcy móch - s. III, odc. 33 / pl:serial animowany dla dorosłych / adult movie/drama / / 00:30:00 / UTC 2014-10-11 18:30:00 : pl:La Maviuta - gender romance - odc. 5 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-11 19:00:00 : pl:Kacza dynastia - s. I, odc. 5 / pl:reality show / show/game show / / 00:30:00 / UTC 2014-10-11 19:30:00 : pl:Jak skończy się świat - odc. 6 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-11 20:30:00 : pl:Zabójcze kataklizmy - odc. 6 / pl:serial popularnonaukowy / technology/natural sciences / / 01:05:00 / UTC 2014-10-11 21:35:00 : pl:Mordercza pogoda / pl:film SF / science fiction/fantasy/horror / / 01:50:00 / UTC 2014-10-11 23:25:00 : pl:Rude Tube - s. I, odc. 7 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-11 23:55:00 : pl:Życie na wybiegu - odc. 1 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-12 00:55:00 : pl:4music / pl:magazyn muzyczny / music/ballet/dance / / 01:00:00 / UTC 2014-10-12 01:55:00 : pl:I Like It - odc. 3 / pl:program muzyczny / music/ballet/dance / / 01:05:00 / UTC 2014-10-12 03:00:00 : pl:Istne szaleństwo - odc. 6 / pl:program rozrywkowy / leisure hobbies / / 01:00:00 / UTC 2014-10-12 04:00:00 : pl:Rodzina zastępcza - odc. 293 / pl:serial komediowy / comedy / / 01:00:00 / UTC 2014-10-12 05:00:00 : pl:Mega Chichot - odc. 31 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-12 05:30:00 : pl:Benny Hill - odc. 63 / pl:program rozrywkowy / leisure hobbies / / 00:35:00 / UTC 2014-10-12 06:05:00 : pl:Benny Hill - odc. 66 / pl:program rozrywkowy / leisure hobbies / / 00:45:00 / UTC 2014-10-12 06:50:00 : pl:Pradawny ląd 7: Kamień zimnego ognia / pl:film animowany / cartoons/puppets / / 01:30:00 / UTC 2014-10-12 08:20:00 : pl:Made in America / pl:komedia / comedy / / 02:25:00 / UTC 2014-10-12 10:45:00 : pl:Zaginiony skarb / pl:film sensacyjny / movie/drama / / 01:55:00 / UTC 2014-10-12 12:40:00 : pl:Dzielny szeryf Lucky Luke / pl:film animowany / cartoons/puppets / / 01:45:00 / UTC 2014-10-12 14:25:00 : pl:Jaś Fasola - odc. 10 / pl:serial komediowy / comedy / / 00:35:00 / UTC 2014-10-12 15:00:00 : pl:Cesar Milan. Przywódca stada - odc. 6 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-12 16:00:00 : pl:Ciekawość - s. I / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-12 17:00:00 : pl:Tajemnice i zagadki przeszłości - odc. 6 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-12 18:00:00 : pl:Włatcy móch - s. III, odc. 34 / pl:serial animowany dla dorosłych / adult movie/drama / / 00:30:00 / UTC 2014-10-12 18:30:00 : pl:La Maviuta - gender romance - odc. 6 / pl:program rozrywkowy / leisure hobbies / / 00:30:00 / UTC 2014-10-12 19:00:00 : pl:Kacza dynastia - s. I, odc. 6 / pl:reality show / show/game show / / 00:30:00 / UTC 2014-10-12 19:30:00 : pl:Wrogie niebo - s. I, odc. 10 / pl:serial SF / science fiction/fantasy/horror / / 01:00:00 / UTC 2014-10-12 20:30:00 : pl:Życie na wybiegu - odc. 2 / pl:serial dokumentalny / education/science/factual topics / / 01:00:00 / UTC 2014-10-12 21:30:00 : pl:Konflikt interesów / pl:film sensacyjny / movie/drama / / 02:00:00 / UTC 2014-10-12 23:30:00 : pl:Śmierć na 1000 sposobów - s. V, odc. 3 / pl:serial dokumentalny / education/science/factual topics / / 00:30:00 /
Regards,Code:General Complete name : /media/video2/DVBT/Przyczajony_tygrys_ukryty_smok.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.54 GiB Duration : 1h 55mn Overall bit rate : 1 913 Kbps Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=4, N=24 Codec ID : H264 Duration : 1h 55mn Bit rate : 1 439 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 50.000 fps Original frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.069 Stream size : 1.16 GiB (75%) Color primaries : BT.601 PAL Transfer characteristics : BT.470 System B, BT.470 System G Matrix coefficients : BT.601 Color range : Limited Audio #1 ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 50 Duration : 1h 55mn Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 211 MiB (13%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (1.20 video frame) Audio #2 ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 50 Duration : 1h 55mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 158 MiB (10%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (1.20 video frame)
f. -
Since you cut out the ads, the video wouldn't happen to consist of not much happening onscreen would it?
Have you tried simply remuxing without the edits? -
Yes, copy means no re-encoding
If it re-encoded, then the mediainfo report would look different with x264 metadata
It looks ok, did you check the output file ? Sometimes avidemux will have errors on the cuts (especially if you didn't cut properly on IDR (key frames) . You might be missing unexpexted parts of the video, or other errors
If output file is ok, unfortunately that implies that your content provider uses disproportionately higher bitrates for the commercials, lower quality for the program
I wouldn't use AVI for the container, there can be problems with AVC in AVI both with muxing and various playback software and hardware
Avidemux is a bit buggy, but it muxes with the field rate, not the frame rate => this can cause problems with some players and hardware
Original frame rate : 25.000 fps -
The commercials have higher bitrates. Unfortunately it doesn't explain the size of output file.
What do you suggest? Other profile for Avidemux or other software (I prefer free software for linux but windows )? I used avi profile due to it worked fine with joined files while mp4 profile - not (the DVB tuner splits files over 4GB). The output file of mp4 profile has the size close to avi files.
f. -
Try MKVMerge to make an mkv out of it and see if it makes any significant difference.
Other than that, it is 2 hours worth of metadata isn't it? And that includes the TV guide apparently, which would be repeated over and over. You've recorded just ONE low bitrate SD channel from the stream so it's possible the metadata is causing the difference. -
Did you check the output? Are parts missing/corrupted ? Sync issues
If you look at the mediainfo stream size of the original
2450 + 285 + 214 = 2949 MiB => that is what non edited audio & video without container should be . That TS overhead is ~5% in this case because File size is 3.1 GiB
For example take tsmuxer, and demux 2 elementary audio & 1 video, it should be close to 2949 MiB
Often what happens with broadcasts are errors/ discontinunities cause drops or glitches - there might be missing parts or errors -
You could try extracting the elementary streams from the MKV, then remuxing them back into a file while forcing the frame rate and see what the duration of the new file is. (Then look at the duration tags for each stream.)
I could not watch this long movie yet (and check it), but I used another program - TSDoctor (unfortunately - not mine). The output files are the same size. TSDoctor inspects the ts-file and doesn't indicate corrupted parts. So, the Avidemux probably works properly (excluding file header) and the ts-file from dvb-t tuner includes extra, redundant data.
f.
Lossless conversion with Handbrake?
By WBFAir in forum Video ConversionReplies: 69Last Post: 1st Sep 2013, 17:35 -
Looking for best size/quality ratio encoding options for MP4 container
By CasanovaFly in forum Video ConversionReplies: 23Last Post: 28th Jul 2013, 22:39 -
Lossless codec + container that convey aspect ratio to Movie Maker 6?
By fvisagie in forum EditingReplies: 10Last Post: 13th Feb 2013, 02:28 -
BRRIP Container Conversion Help
By Cornholio77 in forum Video ConversionReplies: 1Last Post: 28th Dec 2011, 14:41 -
Which codec/container makes lossless video editing possible?
By ilimitus in forum EditingReplies: 14Last Post: 29th Jan 2011, 13:06
