And you're still full of it.
I'm not so sure of that. I'm beginning to suspect that was the plan from the beginning.
I can't tell if you're really as ignorant and clueless as you seem or if this is just a not-so-clever trolling attempt. In any event, we're no longer addressing the original thread topic, so bye.
Results 31 to 33 of 33
To run a 2 pass encode you've got to be able to specify a bitrate or file size in one form or another.
For MeGUI you can specify it in the x264 encoder configuration, but I find mostly it's easier not to. You can leave the encoder configured for single pass, CRF encoding, and use MeGUI's AutoEncode function (you can re-encode the video and audio separately and combine them into a single file yourself, or AutoEncode will do it for you). AutoEncode lets you specify a file size or bitrate. If you do, MeGUI will automatically switch to 2 pass encoding for you. The file size you specify includes any audio and container overhead etc, so MeGUI will work out the required video bitrate. If you specify a bitrate in AutoEncode, I think MeGUI extracts the audio bitrate from that and uses what's left for the video. Something along those lines. I mostly use CRF encoding myself.
Or you can specify a bitrate in the x264 encoder configuration if you want to do it that way..
There's a few aspect ratio calculators to be found on the internet. Or try this one. It's an exe, but it's safe.
YodaResizeCalculator
MeGUI has a similar calculator built into it's Avisynth script creator.
For ITU resizing of DVDs (if you're using ITU) the calculators often tend not to exactly agree by default as they're based on different pixel aspect ratios.
There's a list of the commonly used pixel aspect ratios here:
https://www.doom9.org/showthread.php?p=1058927#post1058927
MeGUI still uses the second ones for ITU: "Almost exact and commonly used ITU-PAR", as I'm pretty sure Gordian Knot does, or you can set custom aspect ratios with either program. Some programs such as Handbrake and Staxrip use the "MPEG-4 PAR".
The creator of the calculator I linked to did it slightly differently, but none of it really matters. When cropping and resizing ITU DVDs they only vary by a pixel or two, and for non-ITU sources or when resizing square pixel video they should all agree. -
Help Me with MeGUI x264 Encoding Settings
By EdsonMarques in forum Newbie / General discussionsReplies: 18Last Post: 5th Dec 2013, 14:47 -
ffmpeg : understanding mpeg4 encoding settings
By feelart in forum Video ConversionReplies: 0Last Post: 11th May 2012, 10:00 -
x264 Mediainfo to MeGUI x264 Settings
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 05:59 -
Understanding TMPGEnc source material settings
By brassplyer in forum Video ConversionReplies: 1Last Post: 5th Mar 2011, 07:41 -
Optimum x264 encoding settings
By zammil in forum Video ConversionReplies: 27Last Post: 18th Dec 2010, 01:32
