Hi.
I have noticed that when I take interlaced footage and export it into mp4 with the proper settings (eg: top field first or bottom field first), mp4 usually has a problem with the interlacing. Eg: during movement you can see the bars and everything is not lined up. But converting from progressive to progressive into mp4 works fine.
I have seen this problem of interlaced converted into progressive mp4 with VHS captures, Hi8mm captures and HD camera footage from a Sony HDR-XR550V.
Is mp4/mpeg4 designed for progressive rather than interlaced? mp2/mpeg2 seems to be better with interlaced video.
Thanks.
I know nothing about MP4s and never encode interlaced, but it sounds like the video isn't being de-interlaced on playback as it should be, which would probably be a player issue. What are you using for playback?
Are you viewing the footage on a monitor as most monitors don't have built in de-interlacing like TVs.
Playing the footage back on a TV should help with the visible interlacing.
Have you tried encoding the footage to progressive as that is what I normally do with interlaced footage which works well with right encoder settings. -
I understand encoding video as interlaced to a certain extent. The video will be de-interlaced on playback and I'm thinking the de-interlacers in hardware players are probably similar to yadif in quality anyway (not that I've done much comparing), but de-interlacing with QTGMC is probably still the best option quality-wise, if you can put up with it being quite slow. And if you de-interlace when encoding, there won't be any interlaced playing problems.
Huh?? Attach a screenshot.
As far as H.264 goes, European 1080i broadcasts, original AVCHD camcorders, and certain Blu-ray releases (like concert videos) all use interlaced encoding just fine.Is mp4/mpeg4 designed for progressive rather than interlaced? mp2/mpeg2 seems to be better with interlaced video. -
Thank you for the information.
I'm using VLC media player to watch video. and a computer monitor.
I tried to change the video clip into progressive for export. That helped a lot. I also raised the bit-rate and in this situation it helped too, even for the interlaced top-field first option.
What is QTGMC? -
By default, VLC doesn't deinterlace. Set it up in "preferences" and choose any of several deinterlace methods, including yadif.
There are better players.
And re-encoded your videos?
http://forum.doom9.org/showthread.php?t=156028Last edited by LMotlow; 22nd Jul 2015 at 07:52.
- My sister Ann's brother
About the progressive to interlaced
By 861stvideoedit in forum EditingReplies: 1Last Post: 11th Apr 2013, 04:18 -
interlaced and progressive in same video. how to make only progressive.
By OmniShadow in forum Newbie / General discussionsReplies: 32Last Post: 19th Sep 2012, 00:44 -
Combining interlaced and progressive
By louis shula in forum MacReplies: 11Last Post: 1st Jul 2012, 12:52 -
NTSC : progressive or interlaced
By mathmax in forum Authoring (DVD)Replies: 54Last Post: 2nd Feb 2012, 08:06 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 10:22
