I have a DVD with some content from a demo reel that I would like to transfer to USB. But it does not play back from the DVD player on my PC. It does, however, play back from my Bluray player. Is there a setting adjustment I can try to allow the PC to read the DVD or is there any way I can extract the DVD audio/video from the Bluray using the Digital Out coax jack?
				Results 1 to 12 of 12
	Tried play with different players like vlc media player?
 Do you see any files on the DVD? If so what folder and files.
	Instead of play...right click on the drive and choose view browse files
 Sounds like you have a video file in avch format not DVD format,
	Perhaps you are right theewizard, but the drop down list does not give me an option to browse files.
	If you can see the file names and extensions
 You see browsing that folder
 If you cannot see the file extensions
 You need to click on folder options and in check hide file extensions
	Can't you put it in your Blu Ray player, play the file(s) and check for a "file Info" option?
	I did and I looked specifically for that but there was no file info option
	You have to ask yourself then.....What can a Blu Ray player play that will not play/open in a computer DVD drive?
 A Blu Ray disc?
	"The greatest trick the Devil ever pulled was convincing the world he didn't exist."
  VHS to DVD Conversion - Which is better?By mreccentric in forum Capturing and VCRReplies: 7Last Post: 11th Mar 2015, 08:07
  Conversion to DVD to IPhoneBy tessieyute in forum Video ConversionReplies: 3Last Post: 14th Apr 2012, 15:08
  Need help with DVD to AVI conversionBy Chain Reaction in forum Video ConversionReplies: 6Last Post: 12th Apr 2012, 16:46
  film to dvd conversionBy snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2010, 19:08
  Frame rate conversion for NTSC to PAL conversion?By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
