    Jul 2015
    Colombia
    for example:
    plz any idea?
  2. Banned
    Oct 2014
    Northern California
    There are plugins for this but the cheapest way is to use Photoshop (or any other tool) to create a transparent image with the items you want and overlay this in an NLE.
    Jul 2015
    Colombia
    maybe this is imposible ?
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Go back and read post #2 again. It's easy to do when you have a transparent PNG image overlay.
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Hahaha, that's pretty funny. I like that. I would say do a screen capture from your phone against a green or blue screen. Then turn it into a PNG and delete the green in a graphics program, like mentioned above.
    Good for a moon or Pluto shot too.
    Apr 2003
    Took about 5-10 minutes using Photoshop and After Effects.
    My Samsung Galaxy GIIS takes screenshots natively, so I shot against a black background, used Photoshop to remove the background, and then assembled using After Effects. Premiere would have worked in place of After Effects too.
