There is some content on an ISO image I would like to view via a video format without burning a disk.
Can Handbrake or another tool simply make a video directly from an ISO image?
	If you mount the ISO image, any conversion program can access the material. Some programs can open ISO files directly. I know Handbrake can open DVD-video ISO files.
 Windows 8/8.1 can mount images natively. If you are using another operating system, you can mount them with Slysoft's free program, Virtual CloneDrive.
	If you can't open an ISO file directly with a conversion program, you can also extract the contents first with a compression program such as WinRar or 7-Zip etc and then you'll have standard DVD files to work with. Probably most compression programs will extract ISO files these days. Or open the ISO with DVDShrink and use the backup function to save it as standard DVD files.
	The old version used to convert my (slysoft) ripped ISOs to mp4 automatically, which worked fine with Quicktime, iTunes & iOS. I installed the latest version 0.10.5.0, and it now creates .m4v files. The files won't open in Quicktime and I couldn't add them to iTunes. Renaming them as mp4 didn't help. However, using Handbrake's Tools->Options->Output Files and set MP4 File Extension to Always Use MP4 fixed it, for me anyway. The mp4 files now open in Quicktime and can be added to iTunes for iPhone.
  Mac and Handbrake CLI - ISO to MKVBy TaT-DK in forum MacReplies: 2Last Post: 13th Jun 2014, 04:40
  [HELP] Handbrake: multiple mkv to mp4 [SCRIPT] with subtitlesBy remuxler in forum Video ConversionReplies: 2Last Post: 13th Feb 2013, 08:29
  Mkv to mp4 with handbrakeBy hilario in forum Video ConversionReplies: 11Last Post: 5th Feb 2012, 14:27
  MKV to MP4 converter besides HandbrakeBy bowmah in forum Newbie / General discussionsReplies: 10Last Post: 19th Dec 2011, 04:04
  AVCHD (DVD) .ISO file, trying to extract original MKV from DVD imageBy SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
						 Visit Homepage
				Visit Homepage
