I'm trying to make a video combined of many different ones and a lot of them are MOV. It was all good until after I reached 2 minutes and now everything that I add is just a green video. I tried the same MOV files in a new vegas project and they work fine. I searched in google, but all I can find is the codecs. I think I have codecs and they're working fine. It's using the qt7plug, which I downloaded from the web, renamed the old plugin and pasted the new one. This was offered as a solution. But it's not working in my case. I tried deleting the whole plugin, but it doesn't work that way. I uninstalled and installed again and still the same.
Anything else I can do?
Tell us more about your original files. My hunch is that they are long-GOP h.264 files. If they came from a phone they are probably variable frame rate. These kind of files require lots of computing power to use. Rewrapping or re-encoding them in handbrake won't make a lot of difference.
Use MediaInfo or Quicktime (CTRL+I) or Vegas properties to let us know the dimensions, frame rate, and codecs of your files.
You may end up having to encode to a more edit-friendly codec like cineform or edius or DNxHD.
Sony Vegas Pro refuses importing a .MOV video file !
By BadDisciple in forum EditingReplies: 4Last Post: 26th May 2015, 07:51 -
Vegas Pro 12 - .mov files crashing comp & not playing video. Please help!
By jcarst85 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2014, 04:10 -
mov (h264) file|: video only in Quicktime, audio only in Vegas MS... :-/
By distendo in forum Video ConversionReplies: 6Last Post: 12th Feb 2013, 18:49 -
How can insert a video in timeline between other video files with Vegas Pro
By siopilos in forum EditingReplies: 2Last Post: 15th Jun 2011, 17:53 -
Seeing what looks like one video over another in Vegas Pro???
By tonyp2 in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:36
