Is there a program that let's me view/extract individual video fields from a DVD or any interlaced video for that matter?
But why ?
Extract one or either field and you get half of the picture. -
Yes, but with 50/60Hz video, a full frame would either be heavily processed or show two interleaved frames together (which is a mess).
VirtualDub with MPEG2 plugin. Add deinterlace filter in "discard fields" mode and you get (half) the raw fields of the video, without any processing (well, except for a YV12->RGB conversion obviously).
In VirtualDub, Deinterlace with duplicate, discard, bob, fold side-by-side. Or use Bob Doubler.
Beware, VirtualDub does not handle interlaced YV12 video properly. It will blend together the chroma channels of the two fields.
In AviSynth: Bob(), SeparateFields().Last edited by jagabo; 15th Jul 2015 at 20:25.
Problem Muxing Raw h264 and Raw AC3
By Malonn in forum Video ConversionReplies: 14Last Post: 29th Jan 2015, 16:21 -
DVD Camcorder RAW Footage
By Mount1003 in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2012, 16:35 -
DVD Bitrate Viewer for Mac OS X???
By bendermac in forum MacReplies: 8Last Post: 17th Nov 2011, 09:58 -
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25
