    Oct 2007
    I'm trying to archive a copy of the first animated batman movie, but the source is so horrible...
    I usually don't mind a grainy source (usually prefer it), but this either seems like it has an excessive amount of grain or has artifacts underneath/accompanying it and no matter what I do nothing seems to really work on it. I've tried various filters like FFT3D, TemporalDenoise, dfftest, MDegrain2 and some others... It also seems to be really blurry and seem to have some edge enhancement which is especially noticeable when the grain starts disappearing. I've tried Dehalo_Alpha but I only seem to be able to clean up a little amount before the filter starts wrecking chaos on everything else.
    Here is a sample clip if anybody could offer some assistance: https://mega.co.nz/#!Bd5XiLrK!lc0qICtmzWPX6YQNzerCaGGvFeOvxlGAb8MIPrHDVOs
  2. That was digitized from analog video tape and has over sharpening halos. They can be reduced with dehalo_alpha(). Try something like
    dehalo_alpha(rx=2.0, ry=0.01, brightstr=2.0, darkstr=1.0)
    You will lose a some small details. Fine tune the paramters to find a compromise you're happy with. Follow up with the usual cleanup for cartoons. Something along the lines of:
    Mpeg2Source("batman_clip.d2v", CPU2="xxxxxx", Info=3)
    dehalo_alpha(rx=2.0, ry=0.01, brightstr=1.5, darkstr=1.0)
    TemporalDegrain(sigma=4, SAD1=200, SAD2=150)
    MergeChroma(aWarpSharp(depth=10), aWarpSharp(depth=20))
    Oct 2007
    Thanks! With the cpu2="xxxxxx" I think the cleared up all the artifacts, so the grainy look actually doesn't look too bad now.
  4. After encoding I noticed that dehalo_alpha() caused a lot of flickering in the vertical stripes of the skyscrapers in the fist shot. And in the "Casino Parking" sign.
    Oct 2007
    I'll check how it looks without dehalo_alpha, the MergeChroma might fix it enough.
    Edit: There seems to be something like ghosting on the source in various spots, using TemporaCleaner makes it much more apparent, here is an example: https://forum.videohelp.com/images/imgfiles/jtCgUwI.png
  6. try this for halos maybe better
    BlindDeHalo3(rx=3.0, ry=3.0, lodamp=25.0, hidamp=25.0, sharpness=100, strength=150, interlaced=false)
    Oct 2007
    Any tips on the blending/ghosting?
  8. Originally Posted by BÌG•bµdd View Post
    I just downloaded BlindDehalo3(). I don't have time to play with it now but that exact command didn't remove the halos at all?
