I've read that video meant to be viewed on interlaced displays is/was filtered in the vertical dimension because it would cause "twittering" otherwise, which is the reason true progressive video (not low-pass filtered) is said to have 30% higher vertical resolution than equivalent interlaced video. For instance, a true 480p would have 30% higher vertical resolution than 480i.
However, at what point in the production chain was the low pass filter applied? Let's say a TV series was shot on film and then telecined to either beta sp or 1-inch tape for a cable broadcast. Were the tapes containing the content already low-pass filtered, or was it low-pass filtered when they sent out the signal?
It was low-passed the moment it was telecined, in other words the moment the film was scanned and transferred to any analog or digital standard definition format such as Beta.
The times certainly have changed, in the old days engineers got away with "explaining" people that low pass filters enhance the video, nowadays people know better!
Any way to see delay applied to audio tracks in an MKV ?
By cpaqf1 in forum Video ConversionReplies: 3Last Post: 22nd Apr 2014, 16:13 -
Vertical low pass filter for telecining
By 90sTV in forum Newbie / General discussionsReplies: 5Last Post: 18th Apr 2013, 11:03 -
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 02:13 -
Need suggestions from pros on how to process low-level audio
By Asterra in forum AudioReplies: 2Last Post: 1st Jul 2011, 20:57 -
Ghads! I just applied for an external job and they know I post here.
By edDV in forum Off topicReplies: 1Last Post: 5th Feb 2011, 00:54
