I have just converted a divx video from NTSC 23.976fps to PAL 25fps using TMPEG. I have now extracted the audio from the original source and need to stretch it to fit the video without making it sound silly.
1 thing that is confusing me, is that I chose 'Do not frame frame rate conversion' from TMPEG, this I believe keeps the exact number of frames but either strecthes or shrinks the films to suit the new frame rate.
If converting from 24fps to 25fps, shouldn't the film be shorter than the original?
My original film was 1:56:33 at 23.976fps and my result was 2:19:52 at 25fps.
Is this right?
Now, I just need to know how to stretch my audio using CoolEdit.
Will it sound stupid being stretched by 24minutes?
cheers
Firtsly, please allow much more than 2 hours before expecting an answer to your questions. Many board users do have lives outside of VCD help you know.
Secondly, to find out how to convert audio/video from NTSC to PAL try reading:
http://forum.vcdhelp.com/viewtopic.php?t=78178
BTW, your new video length of 2:19:52 looks far too long, I reckon it should shrink if you increase the frame rate, as you suggest!
MKV to MP4 audio stretch issues!!!
By wphill in forum Video ConversionReplies: 3Last Post: 18th Jul 2012, 07:42 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Slow down the video to roughly fit with the audio?
By smd721 in forum EditingReplies: 4Last Post: 23rd Apr 2010, 06:55 -
MKVmerge - stretch audio
By snadge in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 06:52 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14
