I am new to the forum and would greatly appreciate your help with this!
I have been processing short (less than 3 minutes, but mostly up to 1 minute) video clips for a video display system that only accepts XVID compressed AVI files.
The processing I need to do is:
- Resize the video to specific non-standard cpixel dimensions; the final size is just short of 16:9, so it usually means cropping or adding a small amount of letterboxing
- Compress using XVID codec
- Process the audio; very often the audio is too low, so I need to at least amplify and often put it through a limiter - I do this separately in Audacity, save out as mp3 and then swap out the original audio when I resize.
Because the target was AVI, all the above could be done pretty easily using VirtualDub, and it all worked reasonably well.
Now, the target system has changed and I need to do the same processing (excluding the XVID compression), but output an MPEG-2 file. In an ideal world, VirtualDub would have an option to save as MPEG-2 and I would not be writing this post, but as far as I can tell, it does not.
So I would like to tap into your collective wisdom for any suggestions you might have as to how I could make this transition to MPEG-2 as painless (both for the workflow and the pocketbook, as I am spoiled by having used freeware) as possible, while maintaining the quality of the original as much as possible.
Thanks very much in advance for your help!
Results 1 to 10 of 10
MPEG PS or TS? You may do this in same way, at the end add only one step ffmpeg (AVI to PS/TS remuxing).
Above for XVid, if your intention is to receive MPEG-2(1?) video and audio then everything will be slightly different.
So please specify in a clear way - what kind of source type you have and what is expected at the end (container type and codecs).
I assume Avisynth will be most flexible way to solve most of your problems (even audio can be processed in one time with video).
Aaaa and personally i would prefer ffmpeg but in terms MPEG-2 video quality seem that HcEnc is better (but avs input expected). -
To achieve high compatibility with consumer disc players, you may be interested in authoring a "DVD Video". But this media format is a lot more than just another kind of media file, it is a whole structure of logical and physical media. Converting to MPEG-2 video (with several constraints) is only one part of a whole process. The audio stream needs to comply to several constraints too (e.g. can't be MP3, but should be AC3 = Dolby Digital in a certain bitrate range). And finally, a "DVD authoring tool" needs to build the logical structure of directories with VOB and IFO/BUP files, even if you don't need menus. Fortunately, the VideoHelp Downloads offer a range of freeware in this area too. By the way, VOB segments are a kind of MPEG PS (ProgramStream) containers with special content to support DVD navigation.
If you prefer to use a single file for the whole movie, e.g. to feed a TV set with integrated DVB receiver from a plugged USB drive, then the MPEG TS (TransportStream) container may be useful instead. Just be aware that the file size may easily exceed the 4 GB limit of FAT32 partitions.
Back to the kernel, MPEG-2 encoding: The mentioned HCenc is indeed very recommendable as high-quality freeware encoder. The new version 0.28 just upgraded to compatibility with AviSynth 2.6 (required minimum now). Feeding HCenc with the content of an AVI file via a trivial AviSynth script (or even one which does some filtering to e.g. scale the video to DVD/DVB supported resolutions and aspect ratios) is not too hard, some converter GUIs may even help you building one in the background. -
You can do it all in Virtualdub and export to Mpeg-2. https://forum.videohelp.com/threads/367446-Virtualdub-External-Encoder-feature
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Pandy,
Thank you very much for your feedback, and please excuse the vagueness in my original post. I hope I can answer with better precision. Please let me preface that there are holes in my knowledge that may lead me to say some dumb-sounding things. I ask for your understanding in advance. (Should have mentioned this in my original post, sorry about that!)
For input formats, it is hard to predict exactly what type of files I will receive as an input, because they come from a variety of sources.
In the past, in addition to properly encoded XVID files, which needed no processing except for some audio level adjustment, I have received swf, OT, and even AVCHD files. Files that needed resizing to the non-standard display size were typically in a standard size, such as 1920 x 1080.
Fortunately, VirtualDub (with the appropriate codec) has allowed me to read and process most files without issues. From what I can gather, the new playback system prefers MPEG-TS, however it accepts PS as well. XVID was needed for the previous playback system, but is not needed for the new system. Based on the files I have received to date, it is very unlikely that I will get any input files with XVID encoding.
Regarding the output format, as mentioned above, the new playback system handles both MPEG-PS and TS, although it looks like it does a conversion when it reads in a PS file and simply copies a TS file.
I was able to get a hold of the file specifications (the format they expect to receive) for another outfit that uses exactly the same playback hardware as I am working with. I think this would be a good target for the output format, as they already have a working system in the field.
Target output format:
Codec: MPEG2 Program Stream
Frame size: 720 x 1280 (they have a nonstandard screen size; they ask you to create the content for the non-standard size and then squeeze it into 720 x 1280, which the playback system then stretches back into the correct full screen size automatically)
Frame rate: 29.97
Aspect ratio: 1.2000
Field order: Upper field first
Encoding: 8-bits
Bit rate: 10 Mbps CBR
Chroma format: 4:2:0
GOP IBBP size: 15
Audio: MPEG1 Audio Layer-2
Sampling Rate: 48000 Hz
Bit rate: 224 kbps
Channels: 2
File extension: *.mpg or *.m2p
I hope this provides the proper information needed. Thank you very much for reading this long post and any guidance you could provide! -
Ok, quite strange requirements but...
As i've wrote earlier - you may follow regular path and instead coding to XVid do same with HCEnc (simple Avisynth script should be sufficient) or you can give a chance to ffmpeg:
Code:rem --- video filter --- @rem set vidf=yadif=mode=1,scale="'if(gt(a,6/5),720,-2)':'if(gt(a,6/5),-2,1280)':sws_flags=spline+full_chroma_int+full_chroma_inp:sws_dither=a_dither",pad=720:1280:(ow-iw)/2:(oh-ih)/2:color=black,format=pix_fmts=yuv420p,setdar=ratio=6/5,tinterlace=mode=4,fps=fps=30000/1001 @set vidf=yadif=mode=1,scale=720:1280:sws_flags=spline+full_chroma_int+full_chroma_inp:sws_dither=a_dither,format=pix_fmts=yuv420p,setdar=ratio=6/5,tinterlace=mode=4,fps=fps=30000/1001 @rem --- audio filter --- @set audf="pan=stereo| FL < FL + 1.414*FC + 0.707*BL + 0.707*SL + 0.177*LFE| FR < FR + 1.414*FC + 0.707*BR + 0.707*SR + 0.177*LFE,compand=0.1|0.1:0.60|0.60:-76/-999|-60/-30|-30/-20|-20/-15|-9.309/-6.0206|0/-3.103:6:-6.0206:-90:0.6,aresample=resampler=soxr:osr=48000:cheby=1:cutoff=0.990:dither_method=triangular_hp,aformat=sample_fmts=fltp:channel_layouts=stereo" @rem --- MPEG2 Bitrate --- @set vbitrate=10000 @set /a vbuffsiz=(%vbitrate%*1500)/3000 @set /a muxrate=%vbitrate%+384 @set /a vbtol=(%vbitrate%*10)/200 @rem --- MPEG2 --- @set mpeg2=mpeg2video -b:v %vbitrate%k -bt:v %vbtol%k -minrate:v %vbitrate%k -maxrate:v %vbitrate%k -bufsize:v %vbuffsiz%k -flags:v +ilme+ildct+cgop -mpv_flags +strict_gop -sc_threshold 1000000000 -alternate_scan 1 -top 1 -g 15 -bf 2 -seq_disp_ext 1 @rem --- MP2 --- @set mp2=libtwolame -mode stereo -ac 2 -b:a 224k @rem --- TS --- @set mpegts=-start_at_zero -shortest -muxrate %muxrate%k -mpegts_original_network_id 15 -mpegts_transport_stream_id 7 -mpegts_service_id 1 -mpegts_pmt_start_pid 256 -mpegts_start_pid 512 -streamid 0:768 -streamid 1:769 -metadata service_provider="Randolphe Prince" -metadata service_name="Feed" @rem --- file --- @ffmpeg -i %1 -vf %vidf% -c:v %mpeg2% -af %audf% -c:a %mp2% -f mpegts %mpegts% -y Feed_%1.ts
to use above you need to create batch file (assumed OS is Windows but Linux batch should be not so different - maybe variable definitions easier to do)Last edited by pandy; 15th Jul 2015 at 10:58.
racer-x,
Thank you very much for the very useful link! And very nice tutorial video!
I had a look and got some good insight into what needs to be done.
Thanks again! -
LigH.de,
Thanks very much for your feedback and suggestions!
I had seen mention of HCenc in internet searches, but was not sure whether it was something I could use. I will give it a try and also compare to ffmpeg, for completeness.
It looks like the light is visible at the end of the tunnel!
Thank again! -
Pandy,
Thanks so much for the script!!! It is really, really appreciated!
I will go through it thoroughly so I can understand what every line does (will take some time for a beginner like me!) .
Thank you again so, so much! -
Transitioning from Camtasia to Sony Vegas 13 and these are my doubts
By rocco123 in forum EditingReplies: 3Last Post: 8th Jan 2015, 21:11 -
MPEG-2 aspect ratio problem when burn to DVD (Will pay $50 for solution)
By prodos in forum Newbie / General discussionsReplies: 25Last Post: 2nd Jan 2015, 23:53 -
Pixilation Issues After Converting From MKV To Avi. Need A Solution
By stoksyXL in forum Video ConversionReplies: 24Last Post: 14th Jul 2014, 06:35 -
DV Avi really the best solution for Video8/Hi8? No HD?
By jouse. in forum RestorationReplies: 4Last Post: 24th Feb 2013, 08:27 -
Convert Webcam Video for TV - uncompressed avi > asf > mov - best solution?
By nakedgun in forum Video ConversionReplies: 0Last Post: 17th Nov 2011, 05:41
