I got the Mag 557 DVD recorder to complement (backup) my Mag 513 DVD recorder. I tried using a 513 recorded +RW DVD on the 557. While it will play the DVD it will not let me delete titles. I then tested formatting a new +RW disk on the 557, recorded something and deleted the title. Taking that DVD back to the 513, I get an error message that the disk cannot be used.
Am I missing some step here or are they really incompatible and I need to buy a new stack of DVDs for the 557?
Thank you.
According to one post I recall reading, the new Magnavox 557 uses a different method for recording/authoring than the Magnavox 513, so it makes sense that one cannot delete individual titles recorded by the other.
Formatting/erasing the whole disk should still work. I have reformatted re-writable DVDs recorded by a DVD recorder from another maker or authored using my PC, and they worked fine. So no you should not need to buy new DVDs for your new Magnavox 557 recorder. All you need to do is watch everything on the disc and then format/erase the whole disk. -
Thanks usually_quiet. I thought that deleting all titles was equivalent to formatting. I didn't realize that there is a way to force formatting of an already formatted +RW disk. I'll have to find how to do that - I didn't see it in the manual. It just says that formatting a "new' disk is automatically done.
I just downloaded the manual for the Magnavox MDR557H/F7. I discovered something unexpected. Unlike all the older models, it doesn't record to DVD+R and DVD+RW.** It can only use DVD-R and DVD-RW discs. It looks like I was wrong about replacing media, if you only have DVD+R and DVD+RW. That stinks!
[Edit]**The manual doesn't mention any recordable media other than DVD-R or any re-recordable media other than DVD-RW.Last edited by usually_quiet; 16th Jul 2015 at 22:25.
You were not wrong. As usual, your information is right. That's yet another error in the manual! See #9:
http://www.avsforum.com/forum/106-dvd-recorders-standard-def/940657-magnavox-557-537-5...l#post24661094
"+R/+RW DVDs - contrary to manual, THE 557 DOES RECORD TO AND PLAY BACK DVD+R AND DVD+RW, even though they're not listed as either Playable or Unplayable in the manual. See one user report: http://www.avsforum.com/forum/106-dvd-recorders-standard-def/940657-magnavox-557-537-5...l#post25041770
No I didn't. It's odd. Being downward incompatible could make sense if they are using a new method/layout to delete files/headers. But the upward incompatibility is not a normal situation. As it can play the disk it has to be able to read the header information, so it should be able to delete it. I suppose the delete software is looking for the "new' format header/files and so doesn't know what to make of the old format.
Getting Remote Control Replacement for Mag DVD Recorder
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2014, 15:07 -
Questions quality Philips DVD+R CMC MAG M01
By gamemaniaco in forum MediaReplies: 26Last Post: 4th Jan 2014, 07:21 -
MAG Dubbing Is messed UP
By Novice20 in forum Newbie / General discussionsReplies: 7Last Post: 14th Jul 2013, 21:41 -
Mag DVD Recorder Recording Nothing
By Novice20 in forum Newbie / General discussionsReplies: 23Last Post: 25th Nov 2012, 12:45 -
Incompatible discs
By caleb89sw in forum DVD & Blu-ray RecordersReplies: 17Last Post: 2nd Jul 2012, 04:02
