Sorry about the wrong language, here's the edit:
Hi everyone,
I used makemkv to save the 3D mvc stream from the orignial 3D ISO into an mkv file, along with the audio tracks I need. My media player can't handle mvc mkvs, though. But after some online research I've learned that you can reverse this process and create a 3D ISO from that mvc-mkv via TsMuxer.
Those forum posts I found described a fairly complicated, multi-step process, though. Yet, what I did was incredibly easy. I just dragged the mvc mkv into tsmuxer, set the output format to ISO, and that's it. The ISO plays back perfectly in 3D on my media player. So my questions are:
1) Is it really that simple? If so, then why the complicated tutorials?
2) Is the result really a proper 3d ISO, without any limitations whatsoever? Or are there any differences to the original ISO? (apart from the missing audio and subtitle tracks, obviously)
3) Why is the resulting ISO bigger than the mvc mkv?
4) In your opinion, is my approach the correct one or at least reasonable (to create 3D ISOs from mvc mkvs I mean)?
Thanks a lot for your help!
Cheers
Enschuldigen zie, wir müssen Englisch sprechen hier.
ScottLast edited by Cornucopia; 14th Jul 2015 at 15:44.
3D DCP to 3D MVC ISO
By arthurm in forum Video ConversionReplies: 5Last Post: 8th Apr 2015, 04:16 -
How to play 3D mkv files? MVC video stream direct from 3D-Blu-rays
By flashandpan007 in forum Software PlayingReplies: 3Last Post: 7th Dec 2014, 04:01 -
Help converting MVC to SBS
By WOODY3d in forum Video ConversionReplies: 1Last Post: 23rd Nov 2014, 01:30 -
Re:Video Streaming in mvc site
By premkumar in forum Video Streaming DownloadingReplies: 2Last Post: 17th Oct 2014, 05:43 -
See a lot on MVC, so.... how can I convert to it?
By Shilar in forum Video ConversionReplies: 7Last Post: 11th Mar 2013, 03:58
