  1. Banned
    Oct 2014
    Northern California
    Just bought this new from the internet to test for about $14
    What do you think genuine of fake Neewer?
    It's already returned to the seller as it is utter trash!
  2. Banned
    Oct 2014
    Northern California
    So out of curiosity I looked for 46mm variable ND filters on Amazon, Adorama and B&H.
    Nothing from reputable brands under about $200.
    But then more issues surface: green casting, IR problems.
    There are workarounds but a four set Tiffen "indie" set sets you back over $800.
    Bottom line, it is costly to make things dark!
  3. Member Cornucopia's Avatar
    No, it's only costly to make things dark with a VARIABLE ND filter. Single design filters (-1stop, -2stops, -4stops, etc) are cheap and yet still high quality. You just have to manually swap them out.
  4. Banned
    Oct 2014
    Northern California
    That's what I got, some Tiffen standard ND screwed on filters.
    They are not bad but not super either.......
    The indie set is not variable but is still not cheap:
    Tiffen Pro Indie HV Neutral Density Filter Kit (4 x 5.65")
    http://www.bhphotovideo.com/bnh/controller/home?O=&sku=764280&gclid=Cj0KEQjww42tBRCO-s...Y&A=details&Q=
    "Only" $821.25, the price of a decent lens!
  5. Banned
    Oct 2014
    Northern California
    After inquiring with Neewer it was established the filter looked authentic.
    Which, unfortunately, does not make things good for Neewer, at least not in my opinion.
    The filter may be budget, but I think it is totally crap quality!
    Buyer beware!
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What exactly is Genuine of Fake supposed to mean?
  7. Banned
    Oct 2014
    Northern California
    Oops.....
