Hi,
I have files saved in the windows video format as recorded in windows media centre the format is dvr-ms. I would like to convert this file and record it onto dvd can anyone please advise what programme I would need to convert this?
Savio
	Please read guides about DVD Video first, you should know the basics already before searching for any tools. Great source: http://www.dvddemystified.com
 Brief: Video must be encoded in MPEG-2 format with DVD Video compliant constraints. Audio should be encoded as Dolby Digital (AC-3). You also need a "DVD authoring tool", because a DVD Video is a whole media structure, not just a file.
 There may be simplified tools like ConvertXtoDVD / AVStoDVD / DVD Flick ... but still, better know what you need and why.Last edited by LigH.de; 13th Jul 2015 at 13:46.
	If you plan to do this often, I recommend buying VideoReDo TV Suite H.264. It can create DVDs from DVR-MS.
 If it is just one file, MCTVConverter can convert DVR-MS to TS. AVStoDVD can create a DVD from a TS file.
 Note that recordings from digital channels often contain transmission errors which throw the audio and video out of sync when they are converted to DVD. VideoReDo can compensate for the errors. Some members here say that ProjectX can do the same for DVB-T TS files, but it doesn't seem to work for ATSC TS files over here in the USA.
 [Edit]I forgot to mention that Cypheros TSDoctor is another piece of software that can compensate for errors in TS files. Like ProjectX, it doesn't work with DVR-MS files until they have been converted to TS and it doesn't author DVDs.Last edited by usually_quiet; 13th Jul 2015 at 17:21.
  converting to dvdBy Brfcrule1 in forum DVD RippingReplies: 1Last Post: 13th Jul 2015, 13:18
  Converting my DVD's to... ?By roelofjan in forum Newbie / General discussionsReplies: 4Last Post: 26th Aug 2012, 00:20
  Converting AVI to DVD using DVD Flick: low quality resultBy e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50
  Converting TS to DVDBy waveydavey in forum Newbie / General discussionsReplies: 1Last Post: 26th Oct 2010, 00:48
  Converting Pal DVD to NTSC DVD with MenusBy LouieLou in forum Video ConversionReplies: 6Last Post: 9th Oct 2010, 17:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
