    Jan 2009
    I currently capture vhs tapes with my Blackmagic Intensity Shuttle with the 4:2:2 10bit codec, from a Panasonic NV-HS930B SVHS player via s-video. But I'm looking to use component instead as its probably the best its going to get.
    Do svhs decks output component via scart? Or is it RGB? If so, I assume I would need this:
    http://www.cypconverters.com.au/video-processors/csy-2100.html
    I'm from the UK so would have to seek one out.
    Otherwise, would have to look for one of these!..
    http://www.globalmediapro.com/dp/A00DZ7/Panasonic-AG-8700E-S-VHS-Hi-Fi-Editing-VTR-PAL/
    How can I tell if the scart output on my svhs player does RGB?
  2. Member Skiller's Avatar
    Oct 2013
    Germany
    Neither. Apart from very very few high end studio S-VHS decks which have additional YPbPr outputs (not via Scart), all S-VHS decks output S-Video and Composite via Scart. There's either a mechanical switch or an option in a menu to switch the Scart output between S-Video and Composite.
    RGB is nonexistent of the world of VCRs.
  3. I doubt you would see any difference anyway. PAL VHS has chroma resolution of about 40x288. Even capturing 4:2:2 is way more resolution than is on the tape. And with only about 5 bits of signal to noise ratio 8 bits is sufficient. 10 bits just gets you more precise noise.
    The difference between composite and s-video is significant because the multiplexed chroma and luma of the composite signal requires a comb filter (all of which are imperfect) to avoid dot crawl artifacts. By using s-video you avoid the need for the comb filter.
