Hi,
I have 3D movies in MP4 File.
I made 3D subtitles with the software "3D-Subtitler".
it made for me Sup subtitles.
How to merage it for ever for MP4 file?
I tried use Format Factory, but it is take lot of time and also i get big file after Recoding.
What to do?
What is the mose easy way to add Sup subtitles to MP4?
Thank you guys!
Results 1 to 13 of 13
Is that your complaint? You would use Format Factory except the resulting files are too large? It will give you whatever size files you tell it to give you. Go back and choose a lower bitrate or higher CRF.
And I don't believe MP4 allows for SUP subtitle files. You should probably convert them to VobSubs (IDX/SUB) -
Have an option to save the subtitles as SUB file.
but how to add sub subtitles to MP4? -
I don't use FormatFactory but in the picture on its page on this site it shows how to add 'Additional Subtitles'. Did you try that?
If you have to ask then it'll take too much time just to learn enough to be able to do it. I might suggest XviD4PSP as a program where you can add VobSubs because it uses AviSynth. It's going to reencode everything, though, something you probably don't want.
I was just going to suggest MP4Box and a GUI but I see no evidence you can just mux VobSubs as all the GUI allows for is a few kinds of text subs. Maybe someone else has some ideas. -
I don't understand.
Which softwares I need use to do this?
it's take lot of time? -
sup is not officially supported in mp4 container
ie. you can't use sup soft subs just by muxing them it. You would either have to hardcode them, or convert them to a supported format
hardcoding can take a lot of time - it depends on the quality settings you set . Hardcoding means re-encoding the video and burning in the subs (making them permanently "written" into the picture, not toggleable on/off) -
They are supported in other containers, just not MP4 . That's the "easy" way. Use something like MKV or transport stream instead
Like others - MP4 only supports 2 subtitle formats ttxt(srt) and idx/vobsub. In 3D Subtitler you can select vobsub idx/sub as output format and mux those with MY MP4Box GUI.
How to add subtitles permanently to existing mp4 h.264 file???
By Patrick_H in forum SubtitleReplies: 20Last Post: 7th Aug 2014, 07:35 -
How to permanently add subtitles to MP4?
By videonewbie22 in forum SubtitleReplies: 4Last Post: 26th Mar 2013, 04:41 -
What app to use? MP4 h.264, want to add embedded subtitles (.ASS?)
By dtleahy in forum SubtitleReplies: 6Last Post: 4th Aug 2012, 18:56 -
How can i encode and add srt subtitles to 720p mp4 file?
By soshipurpleskies in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2012, 16:21 -
how to add subtitles in mp4 movie
By d2idan in forum Video ConversionReplies: 33Last Post: 6th Feb 2011, 23:56
