Is there a device where i can rip multiple dvd/blueray and have it convert my movies also to hard drive to the format i need?
What is the format you need? (audio, video codecs)
If it's bluray standard ts for avchd or whatever it's called, the Avermedia devices like the lgp (bitrate choices are .3 to 60 mbps, not all bitrates fall under blu ray standard compliance) are your best choice with the newest ReCentral software that is hdcp compliant if you google avermedia hdcp. If it is h.264 + aac mp4, probably the hdmi cloner box (bitrate around 10 mbps slightly higher quality than Aver), which will save to a usb or hard drive (hard drive is unconfirmed). You can find out more about these devices on amazon.com . You should only rip uncopyrighted blu-ray or dvd discs, it is illegal to rip copyrighted discs.Last edited by ezcapper; 12th Jul 2015 at 12:46. Reason: expanded answer and gave suggestions
if you want to RIP, aka capture main movie and convert to another format, then its the PC
if you want to Play on one device and Record on to memory card or usb drive, then there are hardware HDMI capture devices
the truest way exact copy of BD or DVD files to HDD is done on a PC with out converting
ripping used to mean "copy" exactly to hard drive
for most people it now means, the process of reading the disc and Converting to another format like mp4 or mkv -
Most all PC format conversion programs just do one at a time.If you have more than once dvd rom in your pc can you convert more than one at a time?
Try VidCoder and you can batch as many DVDs as you have drives and convert them sequentially.
If your PC is fast enough, it doesn't take that long. Most of my DVDs convert to MKV (h.264/AC3) in less than 15 minutes each directly from the drives,
with AnyDVD running in the background.
EDIT: For Blu-ray, I rip to a HDD with AnyDVDHD and convert also to MKV with RipBot. You can run it overnight to do multiple conversions.Last edited by redwudz; 18th Sep 2015 at 18:48.
does exist interlaced format > 25/30 fps?
By marcorocchini in forum Newbie / General discussionsReplies: 8Last Post: 5th Nov 2014, 05:30 -
does exist mp4 plugin for avisynth
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2014, 18:07 -
Does this exist?
By Anakin in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Jan 2013, 05:12 -
After a certain software (may not even exist but thought id ask!)
By SE14man in forum ComputerReplies: 16Last Post: 18th Oct 2011, 18:36 -
Video Stream Harvester - Does this exist?
By rezilient in forum Video Streaming DownloadingReplies: 0Last Post: 14th Oct 2011, 11:37
