You have a DV format video what do you do for editing and archiving?
What the people were doing for 15 years, it had not changed
-using video editor that can edit DVavi and export that DVavi, same quality basically still having originals, store it
-then export it to mp4 or mpeg2 or DVD for viewing, delivery etc. from the same timeline using that videoeditor
-if not happy with videoeditor's rendering quallity (or deinterlacing if that is the case), using lossless intermediate or dmfs and then encode it with whatever suitable encoding software, so it means if videoeditor cannot export lossless or use dmfs you have to make do only with what that videoeditor can render/export -
_Al_ has the obvious answer, but it doesn't appear as a choice in your poll. Why not?
- My sister Ann's brother -
Back in the day i used to transfer the DV file from the tape onto my Hdd using WinDV 123, i then edited that video into a dvd compliant mpeg2 format, retained the Mini DV tapes for archiving, and then kept the mpeg2 file on my Hdd, and Author to Dvd if needed.
Later i would go on to re-convert those mpeg2 files to mp4 using VRD, at a bitrate of around 70% of the mpeg2 bitrate, which is the default bitrate determined by VRD for their mpeg2 to mp4 profile.
Cheers
Video editing/MKV format issues
By rdeffley in forum EditingReplies: 4Last Post: 30th Dec 2014, 16:37 -
Best file format for archiving
By lbeck in forum Video ConversionReplies: 6Last Post: 9th May 2014, 20:34 -
I need Help - Archiving old VHS tapes to Digital Format
By video80 in forum Capturing and VCRReplies: 27Last Post: 27th Mar 2014, 21:54 -
best archiving format
By shredhead in forum Video ConversionReplies: 3Last Post: 3rd Nov 2012, 23:20 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59
