  1. How do you burn a BIN file using nero? Can you ?I have been told you can.
    If so which do you select vcd , cd copy , iso etc....
    I have the latest version of nero 5.5.80 but i still cant see anywhere to do this.
    Atm i am using iso buster to extract the mpeg then dragging the dat file into nero . Both fire burner and cdr win have proved unreliable for me .
    Any help would be greatly appreciated , thx in advance.
  2. Should be a FAQ
    Just go to "file" -> "burn image", and choose the cue file.
    Note that some versions of Nero do hide the ".cue" extension in this file dialog. Just ignore it and select "All files (*.*)" as file type.
