Is there any way to extract back from vcd the mpeg1 file ?
Results 1 to 9 of 9
Convert the dat to mpg file with vcdgear... http://www.vcdhelp.com/convertdat.htm
Hi
AFAIK the .dat file on the VCD is still a regulasr mpg1 file. Throw it into any mpeg1 player, and it will plaback.
Nero is accepting it as a valid solid file for VCD.
Hope that helped
Sorry. This was full of errors.
>AFAIK the .dat file on the VCD is still a regular mpeg1
>file. Throw it into any mpeg1 player, and it will playback.
>Nero is accepting it as a valid source file for VCD.
>(if i remember it right)
Another method that works for VCD and SVCD:
1) Use CDRWIN to make a bin/cue image of your VCD or SVCD.
2) Use "vcdxrip -b videocd.bin" to extract all MPEG files, plus to create an XML description that shows the structure of your VCD or SVCD.
Vcdxrip is part of the VCDImager toolset. Latest version is 0.7.8. -
You VCD people love to make things complicated
Go to download.com and search a little program called Media Raider. It converts the DAT To VCD in 50 seconds!
If all you want to do is convert a DAT file on a VCD back to standard MPEG-1, just use VCDGear. Load up the dat (on the VCD), save as MPEG-1 on your HDD.
You have the added option of correcting MPEG errors as well. This takes no longer than copying the DAT file onto your HDD and does not impact on the quality.
The DAT file is not the MPEG-1 file with another extension so this step should be done.
If you want to do more than just extract a single DAT file, CornelisJ had a good suggestion.
Regards.
Michael Tam
w: Morsels of Evidence -
With VCDGearGUI out of several attempts to covert .dat file to mpeg-1 I only succeeded once. Keep getting error mesaage "Assertion failed:createProcess(0......)".
Can anybody help please.
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 20:49 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 15:00 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 18:30
